VAG COM: Check Battery Voltage - Easy Guide
Nebelwerfer_TDI
Post07-04-2006, 7:51    Subject: VAG COM: Check Battery Voltage - Easy Guide Quote
Hello!
Since not everyone (including me icon_cry.gif) has a compression tester at home, and the 'normal' leak-down test doesn't work with automatic transmissions, I came up with the following idea: Due to the internal resistance of the battery, the on-board voltage drops by a certain amount with each compression event (which is particularly noticeable when starting with a weak battery and the interior lights on).
It would be advisable to disconnect the connector to the ESP (Electronic Stability Program) or the PDE (Piezo Direct Injector) and log the on-board voltage during startup using VAG COM. Then, you can use VAG Scope to view the voltage drops and infer information about the compression (differences between individual cylinders).
What do you think of this idea?
mfg Nebelwerfer_SDI (due to a burst intercooler hose icon_evil.gif icon_evil.gif icon_evil.gif)
Translated on 15-10-2026, 5:00.
Post07-04-2006, 8:07    Subject: VAG COM: Check Battery Voltage - Easy Guide Quote
Mhh... I think that's only partially informative, because the battery's performance also decreases. Can you then infer which cylinder you are currently testing, or is it just about seeing if they are all the same? What do you have then, certainty that they are all equally good or equally bad? icon_smile.gif
Perhaps it could be helpful as a starting point, but I don't think it will achieve much with VAGCOM and an already weak battery... maybe with a "better" measuring device for determining the on-board voltage.
Translated on 15-10-2026, 5:01.
Post07-04-2006, 9:30    Subject: VAG COM: Check Battery Voltage with Hop Test Quote
Nebelwerfer_TDI wrote:
It would be advisable to disconnect the connector to the ESP or the PDE, and to log the on-board voltage during starting using VAG COM. Then, you can view the voltage drops using VAG Scope and infer the compression (differences between individual cylinders).
That's thoughtful, but I think the "low" sampling rate (compared to the compression sequence) isn't sufficient to obtain a meaningful result.
-> It will definitely be better with an oscilloscope icon_wink.gif.
Translated on 15-10-2026, 5:03.
Nebelwerfer_TDI
Post07-04-2006, 10:26    Subject: VAG COM: Check Battery Voltage - Easy Guide Quote
since the battery's performance also decreases,
It gradually and evenly decreases in pressure... but any lack of tension (e.g., a leaky valve) should be noticeable.
So, what do you have then, the certainty that everyone is equally good or equally bad
Basically, it's the same as after the 'Hoppeltest' - but without the ramp section, and also for automatic transmissions icon_wink.gif.
That's a nice thought, but I think that the 'low' sampling rate (compared to the compression sequence) is not sufficient to obtain a meaningful result.
'To address this, a large resistor with 0.1 - 0.5 Ohms might help, at least as long as it doesn't overheat icon_twisted.gif - or a very weak battery, although the control unit still needs a reasonable voltage to function icon_rolleyes.gif.'
-> It will definitely be better with an oscilloscope .
Okay, I'd like something like that too; I once saw it in a used car test - at the ÖAMTC (the same as the ADAC in Germany) - they also measured the starting current using a Hall sensor and then displayed it graphically - that's why I had the idea with VAG COM icon_redface.gif.
Translated on 15-10-2026, 5:05.
Karma: +807 / -0   Thank you, like it!
Post07-04-2006, 12:09    Subject: VAG COM: Check Battery Voltage - Easy Guide Quote
You won't be able to detect anything with VAG-COM and "slow" control units with an approximate sampling rate of 3 Hz. You will, however, be able to detect it with a decent oscilloscope.
Translated on 15-10-2026, 5:07.
Nebelwerfer_TDI
Post07-04-2006, 13:09    Subject: VAG COM: Check Battery Voltage - Easy Guide Quote
@Rainer: What do you mean by 'slow' control units? Are you referring to the old 8-bit ECUs from the 1Z, AAT, or AEL? They aren't really that slow - I even managed to represent the quantity fluctuations of a jerky 1Z engine with them icon_biggrin.gif.
If I replaced the burst intercooler hose this weekend, I'll try it icon_wink.gif.
Translated on 15-10-2026, 5:08.
Post07-04-2006, 13:25    Subject: VAG COM: Check Battery Voltage - Easy Guide Quote
Hi, think about what signals can be sampled with a 3Hz rate, and how quickly your starter motor spins the engine... icon_cool.gif
Nebelwerfer_TDI
Post13-04-2006, 8:52    Subject: VAG COM: Check Battery Voltage - Easy Guide Quote
I finally tried it out - with the predicted result. There was fluctuating voltage, a few sporadic glitches here and there, but no clear, periodic oscillations icon_cry.gif. It would have been too good if that were so easy; still, thank you for your answers!
Translated on 15-10-2026, 5:09.
No new posts Glow Plug Information: Types, Function & More Technical Articles
No new posts Some information about the longlife service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Hoppeltest failed? Next steps: Compression or what now? Diesel Engine Technology
No new posts Diagnosis of PDA? On-Board Diagnostics (OBD)
No new posts OBD II Tuning: How to Tune Your Car Diesel Engine Technology
No new posts Motor Oil Truth: What You Need to Know Diesel Engine Technology
