Hello!
Steffarn
Quote: |
I read the MSW and found errors. The LMM intermittently dropped to approximately 500mg and then rose again to 1100mg. It feels like someone is turning the fuel off and on again.
Does "Error found" mean that you confirmed the behavior in the measurement data?
or it states that there was actually a defect in the LMM (lambda measurement module), and the problem was resolved with a new LMM.
was was gone?
If the VTG (Variable Transmission Gear) is stuttering, and reducing the load (LD) "suddenly" works, then...
When a underswing occurs, a nearly simultaneous drop in the mass flow rate (MFR) is observed.
It's only logical.
With the new mass airflow sensor (installed six months ago), the mass airflow values have indeed increased.
However, the dip in performance during the seemingly "problematic" process of scaling down remains.
Regards, Klaus.
Please provide the German text you would like me to translate into English.
VW Golf III, AFN engine, 165,000 km.
