Does a retrofitted tow hitch for a Caddy manufactured in 2006 need to be reprogrammed in the vehicle's control unit?
Will be? If so, I would appreciate a brief update.
HH
Hello, I have an answer to your question.
It needs to be unlocked by the friendly (VW dealer), but I'm unfortunately unable to tell you how much that will cost.
Hopefully, I was able to help you a little bit.
The body control module must not be coded, nor is it allowed to be coded. In the case of the Caddy, a non-diagnosable control unit is installed, which means, in other words, that nothing needs to be changed. If, unexpectedly, a diagnosable control unit is installed, then the CAN gateway must be coded accordingly, as well as the trailer hitch control unit.
