Another adapter issue?
Post08-10-2002, 11:05    Subject: Another adapter issue? Quote
Hi everyone,
Although the VAGCOM adapter 2.1 works reliably on my laptop, I'm curious about the program's behavior when you exit a control unit (engine, ABS, etc.) using the ESC key.
While disconnecting and reconnecting the device is possible, any new attempt to access the adapter (e.g., selecting a test function or another control unit) results in an "COM port not available" error message.
The LEDs also indicate the reason: LED 3 normally only lights up during communication with the vehicle, but after the ESC withdrawal, it stays on constantly – meaning the COM port is blocked because DTR is high and RTS is low.
Everything works normally again only after closing VAGCOM.
Is this the case with other adapters as well, or is this just a quirk of my specific parts?
Translated on 22-07-2026, 1:02.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts USB Diagnostic Adapter: Access Engine Control Unit On-Board Diagnostics (OBD)
No new posts Residence Time: Another Question Diesel Engine Technology
No new posts Tuning Sausage: Even Better! Diesel Engine Technology
No new posts Intake Manifold Differential Error (575) - Cause Diesel Engine Technology
