Dynamic Maintenance Intervals Explained
cyrano
Post30-03-2006, 11:20    Subject: Dynamic Maintenance Intervals Explained Quote
I would like to learn more about the dynamic maintenance intervals of VAG vehicles.
What measurement parameters are being used, and in which channels is what data being stored, etc.?
Can anyone help me out?
Thank you.
Cyrano.
Translated on 06-09-2026, 21:17.
Post30-03-2006, 12:13    Subject: Dynamic Maintenance Intervals Explained Quote
At least the search function can help you get started.
Translated on 06-09-2026, 21:18.
cyrano
Post30-03-2006, 18:41    Subject: Dynamic Maintenance Intervals Explained Quote
*yawn*... Ugh, this isn't really helping either.
mullemaus
Post30-03-2006, 18:50    Subject: Dynamic Maintenance Intervals Explained Quote
*yawn*, ... Oh man, THAT doesn't really help either.
If you're feeling a bit more awake (*yawn*), try using the /search.php feature just for testing. You can find channels and information there icon_wink.gif. So, don't be too tired, and then proceed with enthusiasm.
Translated on 06-09-2026, 21:19.
Herr Antje
Post31-03-2006, 8:52    Subject: Dynamic Maintenance Intervals Explained Quote
If you can't find anything, try looking for "LL" (Longlife) products.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Post31-03-2006, 9:10    Subject: Dynamic Maintenance Intervals Explained Quote
So, then you really should try being a bit more creative when searching. You can find everything there, from the results of oil analyses to the influence of engine oil temperature for estimating operating conditions, and taking into account brake wear, and so on.
Okay, wake up and start searching!
Translated on 06-09-2026, 21:20.
Herr Antje
Post31-03-2006, 9:29    Subject: Dynamic Maintenance Intervals Explained Quote
So, then you really should try to be a bit more creative when searching.
"What does 'ihr' mean?" Everyone is pointing him to the search function. He says he can't find anything. I suggested he try using a different search term, "to be a little more creative" with his wording.
Aktuell:
Translated on 06-09-2026, 21:21.
Post31-03-2006, 10:09    Subject: Dynamic Maintenance Intervals Explained Quote
This was intended as a helpful "you" addressing all current and future users of the forum, rather than a personal reference. The goal is to keep posts that become overly long and unhelpful to a minimum.
cyrano
Post27-06-2006, 10:39    Subject: Dynamic Maintenance Intervals Explained Quote
I already understood, in a general sense, how the LL interval works.
Where and how these measurement parameters are stored, and how they can be modified if necessary, is a question that is already quite well-defined, but unfortunately, the SEARCH FUNCTION does not provide an answer (unfortunately).
So don't let me die stupid, in case anyone knows!
Thank you.
Translated on 06-09-2026, 21:22.
Post27-06-2006, 11:02    Subject: Dynamic Maintenance Intervals Explained Quote
cyrano wrote:
However, where and how these measurement parameters are stored, and how they can be modified if necessary, is a question that is already quite well-defined, but which the SEARCH FUNCTION unfortunately does not answer (unfortunately).
So, don't let me die stupid, in case anyone knows!!!
The articles contain some information about the WIV reset.
If you change the current values in the oil wear counter, remaining life, and remaining mileage fields, you might get what you want...
Translated on 06-09-2026, 21:23.
Post27-06-2006, 17:28    Subject: Dynamic Maintenance Intervals Explained Quote
So, whoever can read definitely has an advantage...
/viewtopic.php?t=3139&highlight=serviceinterval
/viewtopic.php?t=86&highlight=longlife
...and changing the channels between service visits doesn't achieve anything! Only resetting the device and then re-coding it makes a difference. Therefore, it's not possible to deliberately modify the values.
That's all I can and am allowed to say about it. Please refrain from sending any further inquiries via private message!
Translated on 06-09-2026, 21:24.
