Turbocharger for Tuning: GT1749VA/VB Options
dj1
Post24-05-2006, 16:47    Subject: Turbocharger for Tuning: GT1749VA/VB Options Quote
Since I plan to (still icon_redface.gif) upgrade to a 12mm pump soon, and afterwards I want to run a high boost pressure, the question is whether I can keep my turbocharger (currently: GT1749VA) or if there will be a significant difference (in terms of performance and durability of the turbo).
To be honest, I'm not really keen on buying a new charger and having to install it again if it's not really worth it.
Question for the experts:
Would you leave the GT1749VA installed?
Does it hold 1.5 bar, or perhaps even 1.6 bar?
Has anyone had any experience with this?
Thank you in advance for any helpful tips.
DJ1.
Translated on 24-09-2026, 17:17.
Marzocchi
Post24-05-2006, 23:35    Subject: Turbocharger for Tuning: GT1749VA/VB Options Quote
"VA with 1.5 bar? I doubt it. The VB is already having enough trouble."
Golf IV - ALH - Erstzulassung 9/99
Translated on 24-09-2026, 17:18.
dj1
Post25-05-2006, 10:31    Subject: Turbocharger for Tuning: GT1749VA/VB Options Quote
VA with 1.5 bar? Probably not. The VB already has enough problems.
As far as I remember, the ARL system already operates at 1.5 bar with the VB series.
The vacuum is approximately 1.3 bar.
Surely, there should be some 'wiggle room' available?
DJ.
Translated on 24-09-2026, 17:19.
Marzocchi
Post25-05-2006, 11:14    Subject: Turbocharger for Tuning: GT1749VA/VB Options Quote
As far as I know, there are now about 4 revisions of the GT1749VB turbocharger because there were initially endless problems with the 1.5 bar boost pressure. You might be able to push the chargers in the latest series to 1.6 bar, but you need to be sure that you have one of those.
If you're already thinking about buying something new and want to do some serious modifications, why not consider a hybrid loader?
Translated on 24-09-2026, 17:20.
dj1
Post25-05-2006, 11:21    Subject: Turbocharger for Tuning: GT1749VA/VB Options Quote
Hybridlader? Hmm, weiss nicht lohnt sich der Aufwand? I don't think so.
How can I identify the 'newer' ARL turbochargers?
I've also read that some people run 1.5 bar of boost on the GT1749VA turbo.
The VP2 valve in the shop should be able to handle 1.65 bar.
I think I just need to test it.
DJ.
Translated on 24-09-2026, 17:21.
Marzocchi
Post25-05-2006, 11:46    Subject: Turbocharger for Tuning: GT1749VA/VB Options Quote
I would try 1.4 bar. If you put in 1.5 bar, you should definitely set aside some money for a new bearing!
Translated on 24-09-2026, 17:22.
No new posts Turbocharger Repair 1.9 TDI ASZ Troubleshooting & Guides
No new posts Transporter 7D Turbocharger Pipes: ACV Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan, Pfeifgeräusche vom Turbolader Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger damage or not? Diesel Engine Technology
No new posts Turbocharger Optimization: Worth the Risk? Diesel Engine Technology
No new posts Leistungsverlust bei TDI-PD AUY / passender LMM von DC? Diesel Engine Technology
No new posts VW Golf ALH Turbo: Top or Bottom Removal? Diesel Engine Technology
