ABS/ESP Leak: Find the Source!
euro
Post24-05-2006, 20:40    Subject: ABS/ESP Leak: Find the Source! Quote
My Golf II (engine code: JR) has a leak in the diesel fuel system. I noticed it for the first time today, but I couldn't pinpoint exactly where it's coming from! At first glance, it seemed to be leaking from the black plastic/rubber piece located above the 'OUT' screw. This part looks like a drain, so I would like to know what its purpose is and why diesel fuel is now dripping out of it.
If the description isn't sufficient, I can gladly post a photo of it tomorrow.
P.S. I've been driving for about 800 km with the fuel level at 40%; it would be really unfortunate if that was the cause!
euro
Translated on 28-07-2026, 7:39.
Post25-05-2006, 9:02    Subject: ABS/ESP Leak: Find the Source! Quote
Okay, I can't give you a precise solution: But, if it's leaking after adding oil, that's not entirely unusual, especially since your Golf likely has quite a few miles on it. In that case, the added oil might just be exacerbating an existing problem.
Finding a leak is actually quite simple: Clean the pump and then, after running the engine for a short time, check where the leak reappears. In 90% of cases, you'll have identified at least one source of the problem.
Translated on 28-07-2026, 7:41.
euro
Post25-05-2006, 11:37    Subject: ABS/ESP Leak: Find the Source! Quote
It's coming from the rubber hose of the LDA's bleed valve.
It was open earlier, and it seems to be a mixture of oil and diesel fuel. Could that be the case?
The oxygen sensor (MÖL) is located near the turbocharger hose; what could be faulty there?
The diesel fuel (with water/contamination) is coming from the lower part of the injection pump. I had read that this can happen when running on biodiesel and may disappear if you continue to use biodiesel.
Translated on 28-07-2026, 7:42.
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Radiator Leak: Repair Guide & Info Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B2 CV Joint Leak: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Leaky AVF AGR Valve: Causes & Fixes Diesel Engine Technology
No new posts ESP, ALH engine leak Diesel Engine Technology
No new posts ALH TDI Water Pump Leak? Diesel Engine Technology
No new posts Defective candle Diesel Engine Technology
