Audi A4 AFN engine knocking at 1800 rpm
thom
Post24-05-2006, 23:51    Subject: Audi A4 AFN engine knocking at 1800 rpm Quote
Hello.
Today, I noticed something strange with my car. When accelerating, I hear a very faint rumbling sound in each gear, around 1800-2000 RPM. There's nothing before that RPM range, and nothing after it. If you keep the engine at that RPM range in neutral, the rumbling is still there, but you have to listen very carefully to notice it. It's more noticeable when driving. To me, that sounds a bit like an exhaust system.
Perhaps someone has encountered the same problem before. I think the structure is the same for the Passat and the A4.
Thomas.
Back to top Profile PM Email
isar12
Post26-05-2006, 14:55    Subject: Audi A4 AFN engine knocking at 1800 rpm Quote
"On our A4 (AFN, manufactured in 1996), the catalytic converter has been loose in its housing for a few weeks. It's getting louder and louder, but I suspect it won't be long before my wife (who drives the car mostly) forces me to replace it."
You can hear the noise at a specific RPM, I think around 1500 RPM, coming from the entire exhaust system when you're underneath it. To be sure, I drilled a small hole in the catalytic converter housing and screwed in a sturdy metal screw until the monolith was secure again. It only worked for a short time.
However, the air filter housing is also a common culprit.
Best regards, Rudi.
Wartung statt Schutzbrief!
No new posts Passat 3C 2.0 BKP - White/blue smoke at 1800 rpm, misfires Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Noise: Loud Rumble from 3500 RPM Diesel Engine Technology
No new posts Unter 1800 U/min? Diesel Engine Technology
No new posts AFN Log: Error at 1800 seconds Upload
No new posts Spannrollenbruch nach 1800 km !!! Diesel Engine Technology
