MWB 3/AGR: Meaning of Duty Cycle Ratio
101das
Post30-05-2006, 15:06    Subject: MWB 3/AGR: Meaning of Duty Cycle Ratio Quote
Hello!
Here's a question about the meaning of MWB 3, specifically regarding the EGR duty cycle. Consider a 1.9 TDI engine with an active EGR system. At idle, a value of 10-90% might be displayed, which corresponds to the EGR valve being more or less open. Under full load, the value drops to 4-5%, indicating that the valve is closed.
I took the opportunity to read out various data points from a seemingly "healthy" V6 TDI engine belonging to an acquaintance. At idle, I see an EGR valve duty cycle of 40-45%. However, when accelerating or under full load, this value doesn't decrease to 4-5%, as it does with the 1.9 TDI, but instead increases up to 95.5% and remains stuck there. The actual and target air mass values show no suspicious discrepancies, both at idle and under full load.
The question is: Is the meaning of the MWB3/AGR rate reversed in the 2.5V6 compared to the 1.9? Or is there a defect present? Subjectively, the car drives well and reaches its top speed, but it feels slightly weak at low RPMs.
Passat3B/AFN
Translated on 24-08-2026, 23:43.
Post30-05-2006, 15:33    Subject: MWB 3/AGR: Meaning of Duty Cycle Ratio Quote
Hi.
Is the meaning of the MWB3/AGR rate now reversed at 2.5V6 compared to 1.9?
Yes.
Or is there a defect here?
No, it looks normal.
If there's a problem with the EGR valve, check the mass airflow readings.
Translated on 24-08-2026, 23:45.
101das
Post30-05-2006, 15:52    Subject: Best German Shepherd Breeders: Find Your Perfect Pup Quote
Thank you for the quick response! The world is now back to normal. icon_smile.gif
Passat3B/AFN
Translated on 24-08-2026, 23:46.
No new posts Tastverhältnis Ladedruckregelventil Diesel Engine Technology
No new posts Spritzventil: Tastverhältnis optimieren On-Board Diagnostics (OBD)
No new posts Boost Valve Airflow Ratio Explained On-Board Diagnostics (OBD)
No new posts Tastverhältnis - Klarstellung Diesel Engine Technology
