Classic: Intake manifold pressure regulation deviation on Passat 98
boki2006
joegolf likes this.
Post27-05-2006, 21:28    Subject: Classic: Intake manifold pressure regulation deviation on Passat 98 Quote
Hello everyone,
After carefully studying icon_wink.gif the numerous contributions on this topic, I would like to obtain a "second opinion" on my problem.
Here are the facts:
The mentioned error occurs during rapid acceleration (according to MWB11, at approximately 2.5 bar). According to the vehicle owner, this problem has been occurring for over a year. Back then, maybe once a month or even less frequently, but now it happens on every trip.
The engine is a 1.9 TDI with 110 horsepower and a VTG turbocharger.
The following tests were performed:
- Check the airtightness of the pressure vessel using a vacuum pump.
- With the solenoid valve closed, the pressure in the hose leading to the pressure sensor is approximately -0.8 bar (vacuum).
- Solenoid valve replaced for testing purposes.
- Turbo removed and cleaned at the workshop.
- Check the boost pressure and vacuum in the turbocharger's pressure sensor using a pressure gauge while driving.
- SG swapped temporarily.
- Flexibility of the control linkage with vacuum pump, or... Actuator diagnostics of the control unit checked.
In a post, I came across the following test:
Disconnect and seal the hose from the pressure sensor of the turbocharger.
The charging pressure should not exceed 1.5 bar (absolute).
--> Interestingly, the boost pressure closely matched the target value or the driver's desired level. The peak pressure was approximately 2.2 bar (absolute). I'm also not getting any error codes. According to my understanding of how a turbocharger works, this shouldn't be possible with the guide vanes open, right?!?
My guess is that the pressure sensor isn't reaching the full zero position anymore. Could this happen over time?
Before I start tinkering with the rod, I'd like to hear your opinions!
I took measurements using a laptop. Once with the error present, and once with the turbo function disabled. Each, MWB 3.8.11.
Please find the Excel sheets attached.
Thank you in advance for any helpful information!
Klaus.
Kopie von passat_ohne_turbo_1.xls
 File name:  Kopie von passat_ohne_turbo_1.xls
 File size:  299 KB
 Downloaded:  518 times
Kopie von passat_mit_turbo_1.xls
 File name:  Kopie von passat_mit_turbo_1.xls
 File size:  200 KB
 Downloaded:  464 times
boki2006
Post31-05-2006, 21:45    Subject: Classic: Intake manifold pressure regulation deviation on Passat 98 Quote
Does anyone have an opinion *desperate*?
Karma: +807 / -0   Thank you, like it!
Post31-05-2006, 23:03    Subject: Classic: Intake manifold pressure regulation deviation on Passat 98 Quote
My assumption is therefore: the pressure cylinder is no longer reaching the full zero position? Could this happen over time?
Before I start tinkering with the rod, I would like to hear your opinions!
It's probably like that, or someone messed with it.
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Audi A6 4B 2.5 TDI: Won't Start? Troubleshooting. Diesel Engine Technology
No new posts AGR Deviation in 2.5 TDI BDG Operation On-Board Diagnostics (OBD)
No new posts Exhaust Gas Recirculation (EGR) Error: Deviation. Diesel Engine Technology
No new posts V6 TDI Intake Manifold Pressure Diesel Engine Technology
