Starting problems
maxx
Post01-05-2002, 9:24    Subject: Starting problems Quote
Hello fellow diesel enthusiasts, I'm having the following problem with my A4 1.9 TDI: When I start it, it stalls 2 or 3 times. It runs briefly, but then immediately stalls. I would appreciate it if someone could help me. Best regards, Maxx.
Post01-05-2002, 9:51    Subject: Problems with the immobilizer? Quote
Hi.
If the engine starts normally, runs for about 1 second, and then shuts off again, that's a typical symptom of a blocked immobilizer system.
It can have several causes: the reading coil in the ignition switch may be defective or loose, the transponder in the key may be faulty, or metal objects near the key may interfere with the reading process (e.g., a bulky keychain).
No new posts AAT, 2.5 TDI, year 1996, starting problems, second issue. Diesel Engine Technology
No new posts VW Golf 4 AHF: Starting Problems & Solutions Diesel Engine Technology
No new posts Startup Problems: Common Issues & Solutions Diesel Engine Technology
No new posts Funny starting problems Diesel Engine Technology
