VAG-COM: Engine Control Module - Block 018
Go to page: 1, 2  Next
Chris
Post12-02-2004, 1:26    Subject: VAG-COM: Engine Control Module - Block 018 Quote
Hey everyone,
Has anyone ever logged data for block 018 in the engine control unit (ECU)?
If I understand the description in the label file correctly:
18.0, PD valve status (after 1 minute of idling - coolant > 80°C).
18.1, Cylinder 1, 0.
18.2, Cyl 2.0,
18.3, Cyl 3.0
18.4, Cyl 4, 0.
If the reading is not zero, it indicates a faulty valve, an open circuit, lack of fuel, or air bubbles.
-> Shouldn't the values jump to 1-2-3-4 after one minute of idling at a temperature above 80°C, right?
Has anyone tried this before? It's not working for me, and it might be a possible solution to my performance issues.
Christian.
Translated on 13-08-2026, 20:38.
brezelmann01
Post12-02-2004, 11:33    Subject: VAG-COM: Engine Control Module - Block 018 Quote
Hi!
They should NOT all be set to 80 or any other value; they should remain at '0'. Within this MW block, the PD status is indicated. A value of 0 means "okay," while a value of 1 indicates a fault.
And this:
means:
PD valve status (after one minute of idle operation with coolant temperature above 80°C). Therefore, the engine is at operating temperature!
pretzel
Translated on 13-08-2026, 20:40.
Chris
Post12-02-2004, 11:45    Subject: VAG Com: Engine Control Module - Block 018 Quote
Hi everyone,
Okay.
'But what's written above indicates that if the result is 0, then it implies 'inoperative valve/open circuit/lack of fuel/bubbles'.'
Christian.
Translated on 13-08-2026, 20:42.
PrivatBereich
Post12-02-2004, 13:00    Subject: VAG-COM: Engine Control Module - Block 018 Quote
'if != 0' means 'if not equal to zero' in English. (Pay attention to the exclamation mark, as it means 'not').
Therefore, if the value is zero, everything is fine.
Private.
Translated on 13-08-2026, 20:43.
Chris
Post12-02-2004, 13:54    Subject: VAG-COM: Engine Control Module - Block 018 Quote
Oh, I see.
Okay, that makes sense. I must have been misled by the mathematical notation, where the exclamation mark above the equals sign indicates an equivalence.
Christian.
Translated on 13-08-2026, 20:44.
Post12-02-2004, 16:01    Subject: VAG-COM: Engine Control Module - Block 018 Quote
Computer table is "!=", which means "not equal to".
Java.
"=" is for assignment, "==" is for comparison.
Delphi.
":=" assignment, "=" comparison.
Translated on 13-08-2026, 20:45.
blizzard
Post27-05-2006, 17:48    Subject: VAG-COM: Engine Control Module - Block 018 Quote
Here's a quick question from me.
what does the number 14 or 6 mean in the MWB 018?
The number 6 often appears when starting up.
I found a description, but the two of them are not listed there.
018,0, Status: Pump-Nozzle Valves (BIP | Cylinders 1-4)
; 000 - Error-free regulation.
; 002 - Control during startup.
; 004 - Small injection volume or low mixing ratio.
; 008 - Maximum current reached.
; 016 - GDP outside of standard reporting period.
; 032 - Sampling rate too low.
; 064 - Transformation error.
; 128 - GDP calculation not possible.
018.1, PD valve, Cylinder 1, Setpoint: 0.
018.2, PD valve, Cylinder 2, Setpoint: 0.
018.3, PD valve, Cylinder 3, Setpoint: 0.
018.4, PD valve, Cylinder 4, Setpoint: 0.
I have to mention that I'm using VAG-COM 3.11.
Translated on 13-08-2026, 20:47.
boki2006
Post27-05-2006, 22:38    Subject: VAG-COM: Engine Control Module - Block 018 Quote
The values are likely binary-encoded, meaning that 6 corresponds to the code 004 + 002, and 14 corresponds to 8 + 4 + 2.
klaus
Translated on 13-08-2026, 20:50.
blizzard
Post28-05-2006, 18:09    Subject: VAG-COM: Engine Control Module - Block 018 Quote
"Hmm, not bad. I wouldn't have thought of that."
Although I am aware of binary code.
but it could actually be true.
At one point during the trip, it ran on only three cylinders.
How should this be interpreted? Is it a brief power outage or too much [something]?
It's all so complicated...
Best regards, Blizz.
G4 TDI PD 74kw AXR
5tkm 1xAGR Ventil (Geräusche)
144Tkm 1xEUH Getriebe + Kupplung
2x POPO Heizung geflickt
155TKM PDE Kabelsatz (ruckeln)
240TKM Wasserpumpe hin
244TKM MFA selbst rep.
305TKM LL Druckschlauch (Nasen weg
320TKM GLÜHKERZEN erneuert
Translated on 13-08-2026, 20:51.
blizzard
Post29-05-2006, 9:54    Subject: VAG-COM: Engine Control Module - Block 018 Quote
Yesterday, after my engine went into protection mode.
It's a "15" and it's located in the second cylinder.
What makes up a score of 15?
and where does the rest come from?
G4 TDI PD 74kw AXR
Translated on 13-08-2026, 20:52.
Mephisto
Karma: +14 / -1   Thank you, like it!
Post29-05-2006, 10:29    Subject: VAG-COM: Engine Control Module - Block 018 Quote
001 - I suspect there's a flawed regulation in place.
"Micha"
Translated on 13-08-2026, 20:53.
blizzard
Post29-05-2006, 16:20    Subject: VAG-COM: Engine Control Module - Block 018 Quote
An error was also recorded in the process.
after he entered the protection program.
17671 - Pump-Jet Valve: Cylinder 2 (N241): Implausible signal.
P1263 - 35-00 - -
in the engine protection program!
__________Cylinder 1__Cylinder 2__Cylinder 3__Cylinder 4
MWB13___ -0.85_______2.99_______-1.41___-1.01
MWB18______0_________15_________0_______0
MWB23_____33_______-128________ -1_______5
50 seconds after the restart!
MWB13___-0.31__________0_______0.07____0.16
MWB18______0__________0__________0______0
MWB23_____32_________16_________-5______1
Is the PDE (positive displacement element) on the 2-cylinder engine defective now, or could it just be the seals?
Does a tandem pump have pressure problems?
"Who is kind enough to interpret this for me?"
Thank you in advance.
G4 TDI PD 74kw AXR
Translated on 13-08-2026, 20:55.
boki2006
Post29-05-2006, 21:51    Subject: VAG-COM: Engine Control Module - Block 018 Quote
Do you happen to have the Bosch or VW part number handy?
Klaus.
Translated on 13-08-2026, 20:58.
blizzard
Post30-05-2006, 7:50    Subject: VAG-COM: Engine Control Module - Block 018 Quote
VAG-COM Version: Release 311.2-N
Control Module Part Number: 038 906 019 CR
Component and/or Version: 1.9L R4 EDC G200SG 1437.
Software Coding: 00002
Workshop Code: WSC 00046
Do you mean the data?
G4 TDI PD 74kw AXR
Translated on 13-08-2026, 20:59.
Devilseye503
Post30-05-2006, 23:20    Subject: VAG-COM: Engine Control Module - Block 018 Quote
@blizzard
As you've already been told, the whole thing is probably binary-encoded.
A number 15 would likely correspond to 1111 in the binary numbering system.
The question now is which bit has something to say.
You probably already have it sorted for the 2nd to 4th bits.
only the first one is missing.
greetings
Translated on 13-08-2026, 21:00.
boki2006
Post31-05-2006, 22:43    Subject: VAG-COM: Engine Control Module - Block 018 Quote
Okay, I've done a little research. The list of codes you provided is not correct. For the specific SG (Serial Gateway) that you mentioned, the possible values are as follows:
0: OK.
2, 4, 6, 7, 10, 14, 15, ... and a few more.
Therefore, they are not bit-encoded.
I will get more detailed information later.
Klaus.
Translated on 13-08-2026, 21:02.
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts EA288 2L CR Engine Block Diesel Engine Technology
No new posts AAZ block, JX head, is it possible? Diesel Engine Technology
No new posts Wieviel PS hält der Block vom 1Z aus? Diesel Engine Technology
No new posts Messwert Block 9 Feld 3 Diesel Engine Technology
