Abgasrückführung Regeldifferenz beim AAT
Corvetto
Post17-06-2006, 17:09    Subject: Abgasrückführung Regeldifferenz beim AAT Translating...
[Translating...]
Hallo zusammen!
hatte ja unlängst folgendes Problem:
https://community.dieselschrauber.org/en/viewtopic.php?p=85862#85862
es waren Fehler im Speicher abgelegt....
550 Einspritzbeginn Regelung
519 Saugrohrdrucksensor
560 Abgasrückführung
haben heut mal die ESP eingestellt, und 550 und 519 sind weg...
560 bleibt aber.....und die Symptome ebenso..
kann mir jemand helfen?
Danke!
Audi 100 C4, Bj 1993, MKB: AAT
christians
Post17-06-2006, 21:44    Subject: Abgasrückführung Regeldifferenz beim AAT Quote
Replace the AGR valve gasket with a suitable metal sheet...
I am usually against it, but it is optimal for troubleshooting.
Gruß Christian
Corvetto
Post18-06-2006, 2:33    Subject: Abgasrückführung Regeldifferenz beim AAT Quote
christians wrote:
Why don't you just temporarily replace the AGR seal with a suitable metal plate...?
I'm usually against it, but it's ideal for troubleshooting.
I've tried, but nothing seems to change...
The problem occurs when accelerating, and when coasting, regardless of whether it's at 50 or 160... as soon as the speed is maintained for a longer period, I no longer have enough power when I press the gas pedal.
Thank you.
No new posts P1405 - Exhaust Gas Recirculation (EGR) Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0487 - Exhaust Gas Recirculation (EGR) Throttle Control ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0400 - Exhaust Gas Recirculation (EGR) Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Exhaust gas recirculation (EGR) specifications for the AF... Diesel Engine Technology
No new posts Problem mit Abgasrückführung? On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Korrektur der Abgasrückführung On-Board Diagnostics (OBD)
No new posts Exhaust gas recirculation (EGR) gurgling noises / TDI 130hp Diesel Engine Technology
