Document: Automatic Transmission Leaks 01M (Solution)
Michael II
Post08-10-2002, 16:49    Subject: Document: Automatic Transmission Leaks 01M Quote
AG4/01M
ATF leaks at the bottom of the gearbox
Cause:
Gear oil pan contamination. The actual cause, however, is often the main pressure closure screw.
Procedure:
Before replacing the oil pan gasket, be sure to first check the main pressure seal screw above the oil pan for oil leaks. If there is a leak at the main pressure seal screw, replace the screw with part number N 904 142 01 and tighten it to 15 Nm. After the test drive, check the main pressure closure screw for tightness.
Tschüss
Michael II
Ratings - Document: Automatic Transmission Leaks 01M
No new posts Automatic Transmission: No Rebuild Needed (01K-01F) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN: Oil leak at upper internal thread screw, automatic t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission Fluid Change 01M Golf III Troubleshooting & Guides
No new posts Automatic transmission fluid level Diesel Engine Technology
No new posts Passat VR6 automatic transmission On-Board Diagnostics (OBD)
No new posts Automatic Transmission Volkswagen Golf 3 Transmission, Chassis, Body & Interior
No new posts Automatic Transmission Whining Noise? Diesel Engine Technology
