Engine Control Unit Login
Melda
Post19-06-2007, 21:01    Subject: Engine Control Unit Login Quote
I'm looking for the login credentials to access the engine control unit (ECU) in order to adjust parameters like fuel injection amounts, which is typically a code like "12233" for four-cylinder pump-injector engines.
I need the part for an Audi A6 with a BAU engine, 2.5 TDI, manufactured in 2004, with 180 horsepower.
I would appreciate a knowledgeable answer or explanation regarding this model. Please refrain from making any inappropriate jokes or posting irrelevant comments.
I find this forum very interesting; there's really a lot of valuable information to be found about diesel engines here.
Thank you very much.
Translated on 10-08-2026, 16:13.
mullemaus
Post19-06-2007, 21:06    Subject: Login Engine Control Unit (ECU) Quote
I would greatly appreciate a professional answer or possible explanations regarding this model. Please refrain from making any rude remarks or posting irrelevant content.
If my memory serves me correctly regarding the recent opinions on this matter, such things either don't exist in newer models or are not known. The search function should be able to provide more information. icon_wink.gif
For example: https://community.dieselschrauber.org/en/viewtopic.php?t=15417&highlight=login+motorsteuerger%E4t
Translated on 10-08-2026, 16:15.
Melda
Post19-06-2007, 21:14    Subject: Engine Control Unit Login Quote
Of course, I've also read a lot about it to try and make progress, and that's how I came across these threads. As far as I know, there should be login credentials available for them.
It's really quite frustrating that you can't get anything out of it.
If anyone can help me, I would appreciate it.
Translated on 10-08-2026, 16:16.
No new posts Login Codes TDI / VAG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Engine Control Module Login 8E0 907 401P On-Board Diagnostics (OBD)
No new posts Engine Control Unit (ECU) Login Failed On-Board Diagnostics (OBD)
No new posts USB Diagnostic Adapter: Access Engine Control Unit On-Board Diagnostics (OBD)
No new posts WFS Login: How to Access VW Services On-Board Diagnostics (OBD)
