Torque Relief Valves
christians
Post04-08-2006, 12:01    Subject: Torque Relief Valves Quote
Does anyone know anything about this topic?
It certainly can't be a small amount.
Gruß Christian
Translated on 21-10-2026, 18:10.
christians
Post05-08-2006, 11:36    Subject: Torque Relief Valves Quote
It's been taken care of.
After I finished everything, it simply wouldn't start. I wasn't initially surprised, as it's known to be sensitive to air. However, fiddling with it seems to have damaged the fuel control unit. In the early years, Bosch used solder that wasn't sufficiently temperature-resistant. Perhaps loosening the old fittings caused enough stress to be the final straw.
Great, I'll have checked all the theoretically possible faults of AFB, AKN & Co. soon. I'll probably do the NW (likely referring to a specific component or system) next year, and I'll also check the oil pump chain then...
Gruß Christian
Translated on 21-10-2026, 18:11.
No new posts Torque and driving fun in everyday life Technical Articles
No new posts Diagrams of Torque/Power with VCDS/VAG-COM Technical Articles
No new posts VAG 1.8L R4/5V 125hp (92kW) Naturally Aspirated Gasoline ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Torque Diesel Engine Technology
No new posts Torque AJM 6-G Diesel Engine Technology
No new posts Torque Myths: Debunking Common Misconceptions Diesel Engine Technology
No new posts Torque 1.6 TD JR - Unsatisfactory Diesel Engine Technology
