Documentation: Performance Issues, Error 17964, AKF Motor (Solution)
Michael II
Post09-10-2002, 11:37    Subject: Documentation: Performance Issues, Error 17964, AKF Motor Quote
V8 3.3L engine, AKF type, up to serial number 4D 1N 004 133.
Power shortage, engine entering limp mode.
Error 17964: Boost pressure regulation - lower limit exceeded.
Cause:
The plastic connector between the vacuum line and the vacuum reservoir in the wheel well is detached or cracked.
Procedure:
Rotate the vacuum container by 180 degrees so that the connection faces downwards. Install a new vacuum hose, extended by approximately 730 mm, ensuring it is not under any tension.
Tschüss
Michael II
Translated on 16-07-2026, 14:09.
Ratings - Documentation: Performance Issues, Error 17964, AKF Motor
No new posts Document MKB AKF, Performance Issues, Error 17964 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance Issues, Error 17707, AKF Motor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AKF Motor: Performance Issues & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.4 TDI Turbocharger Problem: Boost Control Error 17964 Diesel Engine Technology
No new posts Engine Idle High: 1250 RPM, Low Power, 6 Errors On-Board Diagnostics (OBD)
No new posts A4 Engine Performance Issues AKN On-Board Diagnostics (OBD)
No new posts Power shortage in ARL engine Diesel Engine Technology
