PIN Assignment Comfort Control Unit
legolas09
Post12-07-2006, 8:37    Subject: PIN Assignment Comfort Control Unit Quote
I installed the 1C0 959 799F comfort control module. This module is integrated into the comfort CAN bus of the Passat and transmits data to the instrument cluster (IC) regarding open doors, etc.
Menem Leon is missing the wiring from connector 1C0 to connector KI (green connector, pins 8/9).
I would now like to implement this myself and try to feed the data about open doors, etc. via CAN bus.
Does anyone know where I can 'tap into' the lines on the 1C0?
Translated on 26-10-2026, 7:55.
Ross-Tech-Support
Post12-07-2006, 19:24    Subject: PIN Assignment Comfort Control Unit Quote
T29/8 = CAN Comfort High.
T29/27 = CAN-KOmfort Low.
Translated on 26-10-2026, 7:56.
legolas09
Post13-07-2006, 10:15    Subject: PIN Assignment Comfort Control Unit Quote
Thank you icon_wink.gif.
BUT I just found something else... so what's the right fit for me now?
'1C0 959 799F Comfort System Control Unit for a New Beetle 02-'.
J393
T23 pin 9 = CAN-High.
T23 pin 6 = CAN-Low.
Translated on 26-10-2026, 7:57.
Post13-07-2006, 11:52    Subject: PIN Assignment Comfort Control Unit Quote
Just check if you have a 23-pin or a 29-pin connector. Then you can answer the question yourself!
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Ross-Tech-Support
Post13-07-2006, 15:32    Subject: PIN Assignment Comfort Control Unit Quote
The central control units with 23 pins are for vehicles WITHOUT electric folding mirrors (eFH), while the comfort control units with 29 pins are for vehicles WITH electric folding mirrors (eFH).
Translated on 26-10-2026, 7:58.
legolas09
Post13-07-2006, 15:42    Subject: PIN Assignment Comfort Control Unit Quote
new_shocked.gif all clear, thank you... therefore, should I get a T29 icon_wink.gif?
Ross-Tech-Support
Post13-07-2006, 15:48    Subject: PIN Assignment Comfort Control Unit Quote
Translated on 26-10-2026, 7:59.
legolas09
Post18-07-2006, 10:22    Subject: PIN Assignment Comfort Control Unit Quote
Okay, I've now connected it, and it's working great... but I only had the T23 connector icon_wink.gif.
 File size:  473.54 KB
 Viewed:  1336 times
No new posts ECU Pinout: Wiring Diagrams and Information On-Board Diagnostics (OBD)
No new posts 12V Socket Wiring: Pinout and Connections Diesel Engine Technology
No new posts Relay for VW Golf 4 TDI AXR Engine Electrical Systems, Vehicle Electronics, Multimedia
No new posts BMW E46 Connectors & Pinouts (10c Tuning) Diesel Engine Technology
