Caddy Trailer: Buy, Sale & Accessories
Hemminger
Post27-04-2006, 13:36    Subject: Caddy Trailer: Buy, Sale & Accessories Quote
Does a retrofitted tow hitch for a Caddy manufactured in 2006 need to be reprogrammed in the vehicle's control unit?
Will be? If so, I would appreciate a brief update.
HH
Translated on 27-09-2026, 8:18.
Schwarzfahrer
Karma: +0 / -1   Thank you, like it!
Post13-07-2006, 21:09    Subject: Caddy Trailer: Buy, Sale & Accessories Quote
Hello, I have an answer to your question.
It needs to be unlocked by the friendly (VW dealer), but I'm unfortunately unable to tell you how much that will cost.
Hopefully, I was able to help you a little bit.
Back to top Profile PM Email
Post13-07-2006, 21:40    Subject: Caddy Trailer: Buy, Sale & Accessories Quote
ECU address 9 (vehicle network), then long coding.
Modify byte 4 of the tool included with the diagnostic system.
Translated on 27-09-2026, 8:19.
Ross-Tech-Support
Post13-07-2006, 22:45    Subject: Caddy Trailer: Buy, Sale & Accessories Quote
The body control module must not be coded, nor is it allowed to be coded. In the case of the Caddy, a non-diagnosable control unit is installed, which means, in other words, that nothing needs to be changed. If, unexpectedly, a diagnosable control unit is installed, then the CAN gateway must be coded accordingly, as well as the trailer hitch control unit.
Translated on 27-09-2026, 8:20.
Post14-07-2006, 6:19    Subject: Caddy Trailer: Buy, Sale & Accessories Quote
Hmm, are they using recycled parts, or did the workshops make too many adjustments to the previous models?
Ross-Tech-Support
Post14-07-2006, 15:43    Subject: Caddy Trailer: Buy, Sale & Accessories Quote
There are probably several reasons, but the actual answer will likely remain forever beyond our grasp.
No new posts Oil in coolant Caddy SDI BDJ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Caddy Tailgate 2004-2013 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Trailer On-Board Diagnostics (OBD)
No new posts Trailer Coding in Engine Control Unit (ECU) On-Board Diagnostics (OBD)
No new posts Should I balance the trailer wheels? Transmission, Chassis, Body & Interior
No new posts BLS stuttering/freezing, especially when towing a trailer Diesel Engine Technology
