Cruise Control Problems: Troubleshooting Guide
Christian_LOS
Post27-07-2006, 10:05    Subject: Cruise Control Problems: Troubleshooting Guide Quote
Hello to all you diesel mechanics!
I'm having a problem with the cruise control in my car! I drive a Seat Toledo 1.9 TDI.
My cruise control is not working! And when I read the error codes, it only shows "speed signal implausible."
Please help!
Best regards, Christian!
Translated on 08-08-2026, 11:31.
Back to top Profile PM Email
Post27-07-2006, 10:28    Subject: Cruise Control Problems: Troubleshooting Guide Quote
... there are many 1.9 TDI Toledos available.
Please provide the engine code. It should be listed in the service booklet.
Or at least the year it was built.
PS: Without the signal, the cruise control won't work.
Does the speedometer show the correct speed?
Is the sender unit on the transmission working correctly?
What speed does the engine control unit (ECU) display when the speedometer shows a certain value?
Translated on 08-08-2026, 11:33.
Christian_LOS
Post27-07-2006, 12:36    Subject: Cruise Control Problems: Troubleshooting Guide Quote
Hello and thank you for your help already!
Okay, so that's a BMW 1 Series from the year 2001.
The speedometer is working and displaying the correct speed. However, the automatic climate control system is not receiving a speed signal, but it *is* receiving a RPM (revolutions per minute) signal.
Translated on 08-08-2026, 11:34.
Nebelwerfer_TDI
Post27-07-2006, 16:22    Subject: Cruise Control Problems: Troubleshooting Guide Quote
Check the fault memory of ALL control units (ECUs). If you have a broken wire, it's possible that communication between the ECUs is not working. For example, my transmission ECU writes an error to the memory if the engine control unit is incorrectly coded or has been removed.
Translated on 08-08-2026, 11:35.
Christian_LOS
Post27-07-2006, 19:02    Subject: Cruise Control Problems: Troubleshooting Guide Quote
"I've already had it checked. I can clear the error code, but then when I drive and try to activate the cruise control again, the error reappears! It says 'speed implausible'! That's all it says! At least, that's what a VW diagnostic tool shows. I don't have a wiring diagram either! And you can't even get a repair manual for this vehicle!"
Translated on 08-08-2026, 11:36.
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tempomat (GRA) Golf 5/6/7, Retrofitting Procedure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Altea horn not working, cruise control Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Problem: Troubleshooting & Solutions Diesel Engine Technology
No new posts agr new problem Diesel Engine Technology
No new posts Central Locking Problem: Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts V6 TDI fuel injection pump problem Diesel Engine Technology
