Canide
29-07-2006, 0:16 Subject: Bosch EDC15 Wiring Diagram Needed |
Hello everyone,
Does anyone happen to know where I could find a wiring diagram for the control unit mentioned above? One of the transistors looks suspicious, and I would like to understand its function.
Thank you for your help!
Canidae.
Translated on 10-08-2026, 19:39.
bastion Blaumann
29-07-2006, 9:42 Subject: Bosch EDC15 Wiring Diagram Needed |
You can only obtain a circuit diagram for such a device from Bosch, and even then, only if you work there and have a certain security clearance.
These circuit diagrams are actually trade secrets.
A4 Avant 08/01 AWX 05/08-
Translated on 10-08-2026, 19:40.
Canide
29-07-2006, 11:38 Subject: Bosch EDC15 Wiring Diagram Needed |
Thanks for the tip. I have a friend who develops software for control units at Bosch; I'll reach out to him and see if he can get something like that.
Canidae.
matthiasTDI96 Profi-Schrauber
29-07-2006, 11:58 Subject: Bosch EDC15 Wiring Diagram Needed |
Good luck!
Translated on 10-08-2026, 19:41.
Rudi Guest
29-07-2006, 14:37 Subject: Bosch EDC15 Wiring Diagram Needed |
...I have an acquaintance who develops software for engine control units at Bosch; I'll contact him to see if he can get something like that.
If it comes out, that was likely to be his last assignment from Bosch, and the employee...
The person who provided him with the documents has lost their job (and may also face further consequences).
Advertisement for both...
...and that for something that didn't help anyone, because the installed parts are inaccessible.
You can't really get anything that isn't Bosch-specific (almost everything with more than three legs is).
It's better to get a new/different ECU (Engine Control Unit).
Rudi
Translated on 10-08-2026, 19:42.
Canide
29-07-2006, 15:49 Subject: Bosch EDC15 Wiring Diagram Needed |
Hello Rudi,
It doesn't cost anything to just ask him. I already had another control unit installed for over €1,000 (!), and they gave me the old one back. I suspect the defect is in that component. I also saw on sender.de that they repair control units there, so maybe it's still worth it for my old one. However, I have to mention that my car ran better with the old, then defective, control unit than it does now with the new one (black smoke, no power where there used to be, occasional stalling at 1,500 rpm even when releasing the accelerator, the engine once kept running even after being turned off, fuel consumption increased by about 1 liter per 100 km, etc.). Next week, the car will go back to the Bosch service and will stay there until everything is fixed.
Canidae.
Translated on 10-08-2026, 19:44.
Rudi Guest
29-07-2006, 16:35 Subject: Bosch EDC15 Wiring Diagram Needed |
What is the part number for the control unit (is it the same for old and new versions?)?
Did you (or a previous owner) have it tuned?
If you like, please take a picture of the control cabinet where the potentially defective component is located.
recognizing is.
Rudi
[edit] Postscript:
How did it 'die' / What error message led to the replacement?
[edit]
Translated on 10-08-2026, 19:46.
Canide
29-07-2006, 17:19 Subject: Bosch EDC15 Wiring Diagram Needed |
Hello Rudi,
Legacy part number: 0 281 001 997
New part number: 0 281 001 997
Ich habe das Fahrzeug neu gekauft vor knapp sechs Jahren und nie was am STG verändert. Angefangen hat alles damit, daß das Auto beim Einkaufen auf dem Parkplatz (Motor noch warm) nicht mehr angesprungen ist. ADAC konnte nix finden, also in die WS geschleppt, die konnten auch nix finden und plötzlich lief er am nächsten Tag wieder ohne Probleme. Nach ein paar Tagen hat´s mir beim Anlassen einen Injektor zerstört (Kontakt oben am Injektor weggebrannt). Injektor getauscht und alles lief wieder. Wieder ein paar Tage später ist er dann im Leerlauf ausgegangen und ließ sich nur sehr schwer wieder starten (besonders wenn kalt, nur mit Startspray). Daraufhin hab ich ihn dann in die WS gefahren, fünf Kilometer davor hat er dann ganz den Dienst quittiert, ist an einer Stop-Kreuzung wieder mal ausgegangen und nicht mehr an. Die haben ihn dann da abgeholt und untersucht, konnten am Motor nix finden und haben ihn dann zum Bosch-Dienst. Die haben dann das STG getauscht, danach lief er zwar wieder, aber wie schon geschrieben mit den genannten Fehlern. Here's a picture of the STG (control unit) and the injector. I suspect the defect is in the second component from the left at the bottom (R4389), as the circuit board around its leftmost pin appears slightly darker, and the solder on the four ground contacts of the component (at the bottom edge of the picture) seems to be corroded or eaten away.
http://www.felix-mey.com/laguna/STG.jpg
http://www.felix-mey.com/laguna/Injektor.jpg
Canidae.
Translated on 10-08-2026, 19:48.
Styrian
29-07-2006, 19:56 Subject: Bosch EDC15 Wiring Diagram Needed |
...so first of all, I doubt I'll find such a part anywhere...they are definitely not standard parts. Secondly, the part seems okay...if the power transistor (if it is one) has burned out, you would see that quite clearly, and this part also looks very strict in its construction. Possibly, this control unit ("STG") is "refurbished," which might suggest a somewhat "careless" soldering job. On the other hand, unfortunately, it's impossible to make completely accurate statements based on the photo alone (you have to see the part, tilt it, smell it, feel it, and ultimately measure it  )...although this photo was actually taken quite well.
...BTW...have you already mentioned the vehicle type/vehicle data here, or have I missed something  ???
Best regards, Styrian.
Translated on 10-08-2026, 19:49.
Canide
29-07-2006, 23:02 Subject: Bosch EDC15 Wiring Diagram Needed |
Hello Styrian,
Thank you for your assessment. I certainly hope that they didn't install a "reconditioned" part in a new car back then! By the way, it's a Renault Laguna 1.9 dCi manufactured in 2000. Perhaps I should have this part checked by "qualified professionals," but then I wonder where these companies get the necessary circuit diagrams if they claim to be able to completely overhaul the ECUs  .
Translated on 10-08-2026, 19:51.
Ross-Tech-Support Profi-Schrauber
29-07-2006, 23:09 Subject: Bosch EDC15 Wiring Diagram Needed |
When it comes to the Laguna, you should probably check the area around the engine wiring harness...
Translated on 10-08-2026, 19:52.
Canide
29-07-2006, 23:21 Subject: Bosch EDC15 Wiring Diagram Needed |
Are there any known issues with this? I often read the Renault forums, but I can't recall seeing anything like that mentioned. If there are problems, what parts tend to fail?
Canidae.
Translated on 10-08-2026, 19:53.
buzbuz0
Joined: 09/17/2005 Posts: 4 Karma: +0 / -0 Location: neumarkt am wallersee
30-07-2006, 8:09 Subject: Bosch EDC15 Wiring Diagram Needed |
Hello Canide!
Maybe this will help you: http://www.hitzpaetz.de/ Repair of electronic control units.
Best regards, buzbuz0.
Translated on 10-08-2026, 19:54.
