Since my dual-mass flywheel (DMF) seems to be defective, the clutch makes a howling noise when starting, and the pedal also vibrates when you press it, I would like to replace the entire clutch assembly.
So far, I've often been recommended Sachs as a good and affordable manufacturer.
Does anyone know the part numbers for the components I need?
The car is not tuned, and sometimes the boost pressure is too high due to VTG problems, but it is within the maximum specification of
,5 bar.
The new clutch should fit the existing bell housing and be slightly stronger than the VAG clutch.
To be exchanged:
Momentum, ZMS.
Clutch disc.
Printing plate.
Pull-out bearing.
The nearest VAG workshop quoted 1200 euros for the replacement of the above components, including materials. Since I find that too expensive, I'm trying to save money on the materials without having to accept a significant drop in quality.
I only found general information on the Sachs website.
We also need a dealer for Sachs in Austria.
macro
