How it works, Terms of Use
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Upload
Post01-08-2006, 10:34    Subject: How it works, Terms of Use Quote
In this forum , it is possible to upload very large or multi-linked files, such as VCDS log files, videos, audio documents, or even digital images taken yourself of your own car. To do so, simply create a post in the 'Upload' forum and click the 'Add attachment' button.
Dokumente die zu einem einzelnen Thema gehören, bitte direkt im Thema hochladen.
Please do not post any text or problems here; use this space exclusively for uploading files. The purpose is to have all uploaded files visible in a central location.
A link in the description to a resource related to the topic of the file(s) would be helpful.
Here's a helpful guide on how to create meaningful log files with VAG-COM/VCDS for successful troubleshooting.
In the VCDS - RKS distribution available in the online shop, KDataScope is already included. This tool is used for analyzing VAG-COM/VCDS log files and should be utilized. For customers who have already purchased VCDS elsewhere, it is available here.
Attention: Unauthorized uploading of files protected by copyright will result in the deletion of the user and the uploaded files! In cases of serious violations, the administrator expressly reserves the right to report the action to the authorities.
Verpfuschte VCDS CSV Dateien werden gelöscht, es kann doch nicht so schwer sein, die Datei einfach nur hochzuladen ohne drinrumzufummeln!
If you are unsure whether a file can be uploaded, please ask the administrator.
The administrator.
Translated on 11-07-2026, 6:26.
No new posts Diagnostic Cable Issues: 20m Cable Not Working. On-Board Diagnostics (OBD)
