Is it possible to perform a diagnosis on a Peugeot 406?
fricki
Karma: +7 / -3   Thank you, like it!
Post22-08-2006, 7:39    Subject: Is it possible to perform a diagnosis on a Peugeot 406? Quote
I used to own a Vento and enjoyed being able to read the error codes using an OBD2 interface.
Now I wanted to ask you if it's possible to do the same thing on my Peugeot 406 (manufactured in 2001), since the connector (at least visually) seems to be the same as the one on the Vento.
Thank you very much.
Karma: +805 / -0   Thank you, like it!
Post22-08-2006, 9:29    Subject: Is it possible to perform a diagnosis on a Peugeot 406? Quote
Yes, OBD2 should work on all 406 models from the year 2000 onwards, regardless of whether they are gasoline or diesel engines.
An interface with ISO9141-2 capability is sufficient, such as one of the semi-professional diagnostic systems with KKL support.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Review and Installation: Kenwood KDC-DAB 4551U in a Peuge... Troubleshooting & Guides
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts A6 4A: No Diagnosis Possible On-Board Diagnostics (OBD)
No new posts VAG-COM Diagnosis for PSA (Citroen): Possible? On-Board Diagnostics (OBD)
No new posts Audi V8 D11: Diagnosis Not Possible On-Board Diagnostics (OBD)
No new posts Car Diagnosis: Expert Advice & Tips Diesel Engine Technology
