_DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 (Articles)
🔗 ⭐ 🖨 Dieselschrauber - Index » Technical Articles
dieselschrauber Post10-03-2007, 16:58
Intake air temperature on Audi A3 TD I , Engine code AHF
_DEFINE12. This article describes the behavior of the intake air temperature with the example of the Audi A3, engine code AHF (110PS TDI).
Historical Background
Due to a faulty repair of the front bumper of my A3, I resorted to self-help to restore the correct ventilation of the air-to-water cooler.
Here, I attempted to optimize the cooling of the air-to-water cooler by using the airflow, by making the ventilation front as wide as possible and additionally installing ventilation holes in the wheel arch on the back of the air-to-water cooler. The ventilation holes in the wheel arch, because the distance between the air-to-water cooler and the wheel arch is only a few cm, and before the warmed cooling air could only flow directly downwards through the air-to-water cooler.
Modified Airflow:
Luftzuführung, LadeluftkühlerLuftabführung, Ladeluftkühler
Air ducts closed for measurement:
For comparison, the original air intake of a similar vehicle:
Luftzuführung, Ladeluftkühler originalLuftzuführung, Ladeluftkühler original, groß
Measurement of the intake air temperature
To determine whether the ventilation openings in the wheel arch have an effect on the intake air temperature, this was recorded using a diagnostic tool, with both the ventilation openings closed and open.
Measurement conditions:
  • Outside temperature 19°C
  • Boost pressure at > 190 km/h ~1.05 bar (full throttle)
  • Two measurements in opposite directions
Measurement values
Ladelufttemperatur, offenLadelufttemperatur, offen, Gegenrichtung
Ladelufttemperatur, zuLadelufttemperatur, offen, Gegenrichtung
Result
The openings in the wheel arch do not significantly change the intake air temperature.
Therefore, the openings available as accessories for the wheel arch are not relevant for the ventilation of the air-to-water cooler, at least for this vehicle model.
Whether the slightly enlarged air intake openings at the front, compared to the original, have any effect, can also be doubted.
If anyone has the opportunity to measure the maximum intake air temperature at high speed on their TDI (110PS, engine code AHF, AFN etc.), I would appreciate it if they could share the results.
Therefore, before cutting into the Radhausschale (intake manifold), it is necessary to check whether the original air intake openings are sufficient after the LLK (Long Life Kit). An example where they are not sufficient is the Skoda Fabia with the RS bumper.
Further options for reducing the intake air temperature include installing a larger air-to-water intercooler or water spraying before the air-to-water intercooler.
KFZ-Diagnose Shop
Ratings - _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3
Average rating: 4.20 - worst rating: 3 - best rating: 5 - number of ratings: 5 - View ratings
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Coolant Temp Sensor for Audi Convertible Upload
No new posts Intake air temperature? Diesel Engine Technology
No new posts Charging Air Temp/Pressure Sensor: Do You Have It? On-Board Diagnostics (OBD)
No new posts Diesel Temperature & Intake Air Temp Under Load Diesel Engine Technology
