Engine Problems: Black, Smoking Crankcase Ventilation
Go to page: 1, 2  Next
MarkusAFN
Post24-08-2006, 19:22    Subject: Engine Problems: Black, Smoking Crankcase Ventilation Quote
Hello everyone,
I could use your advice again... (The search function couldn't directly help me.)
First, let's talk about the car:
Golf3 AFN, 230,000 km, no chip tuning or modifications, original injectors, coolant level stable and clean, turbo boost hose seems to be leak-free, ...
I'm having a relatively complex problem with my AFN.
'Firstly, the engine is leaking oil from the lower outlet of the crankcase ventilation system (see picture). The oil seems to be being forced out from here. Currently, I'm leaving a 1-2 cm oil stain on the ground in front of the house every day.'
The engine starts to produce a lot of black smoke under higher loads, especially the first time after starting the engine. This starts above approximately 2000 RPM and 0.5 bar of boost pressure. There's already a significant amount of carbon buildup visible at the exhaust pipe...
I did a small compression test today. I used 3rd gear, a steep downhill slope, and took a compression reading every ~0.5 seconds. I couldn't detect any differences.
When the engine is idling, and I remove the oil filler cap, I can feel relatively strong pulsations. A piece of paper (like a paper towel) placed 5 cm away from the center of the opening starts to flutter significantly (2 cm).
I am now imagining the following scenarios:
A) One or more piston rings or valve stem seals are broken, which causes higher pressure in the ventilation system. When I ride with higher loads, so much oil comes out through the ventilation system that it makes a gurgling sound. This is also the reason for the oil loss.
B) The pulsation seems normal (I'm not an expert), and in my case, it's likely that one or more fuel injectors are faulty. This wouldn't be surprising given the mileage.
Oil leak due to a damaged seal on the nozzle.
I would like to hear your opinions on A) or B). Or maybe even a C????
Tips and tricks, what else can I check?
More information:
The car has mostly been driven short distances (less than 10km) for the past 2 months. Oil consumption has been low so far (less than 1 liter within the change interval), but the current consumption is unknown. The engine starts well and responds well to acceleration; the performance seems normal under partial load.
I'm not putting it under heavy load right now (not that it's going to break!), so I can't say for sure if it's still performing at full capacity.
http://www.rushseven.com/Diesel.jpg
Best regards and thank you.
Markus.
Translated on 06-09-2026, 16:04.
MarkusAFN
Post24-08-2006, 19:24    Subject: Engine Problems: Black, Smoking Crankcase Ventilation Quote
Okay, here's some information about the image.
The fitting is located to the left of the oil cooler filter.
A large portion of the deposits are caused by the mileage.
The oil comes out from here, runs down the front of the engine block, into the cover underneath the oil pan, and then drips out through the opening in the drain plug.
Translated on 06-09-2026, 16:08.
Jochen_145
Post25-08-2006, 12:38    Subject: Engine Problems: Black, Smoking Crankcase Ventilation Quote
Hi, have you checked the boost pressure?
It would be interesting to know if the boost pressure is actually fully achieved and how long it takes to build up the boost pressure. This could be the source of the 'russproblem' (presumably a specific issue).
Can you measure the compression of your engine in bar?
It is normal for the pressure to increase and decrease during the operating cycle.
Actually, the pressure in the engine head is increasing, but not significantly. However, based on your description, it's difficult to say exactly how much it's increasing.
It is fundamentally possible for piston rings to be defective, allowing combustion pressure to leak into the crankcase. However, in such cases, the engine's power output is usually reduced.
My suggestion: Measure the compression, record the usual engine parameters, and publish them. That way, you'll have more information and won't have to guess.
Best regards, Jochen.
Translated on 06-09-2026, 16:09.
MarkusAFN
Post25-08-2006, 16:41    Subject: Engine Problems: Black, Smoking Crankcase Ventilation Quote
I haven't measured the boost pressure. Since I noticed this issue (which, in my opinion, happened quite suddenly), I've only been driving with the most economical fuel setting. icon_confused.gif
I'll definitely do that sometime soon. I have an LDA installed, so it should be fairly quick.
I'll also be doing a compression test. I need to find a workshop that can do that (through the glow plug housing, right?). Most larger garages should be able to do it.
Thank you for the tips...
Until the days...
Have a nice weekend...
Translated on 06-09-2026, 16:11.
MarkusAFN
Post05-09-2006, 19:40    Subject: New Insights: [Topic] Revealed Quote
Hello everyone,
I picked up my car from the dealership today.
The compression test (performed via the glow plug threads) indicates the following:
Mileage: 231,474 km
Cylinder 1: 18.9 bar.
Cylinder 2: 20.3 bar.
Cylinder 3: 19.5 bar.
Cylinder 4: 19.2 bar.
According to Volkswagen's statement, everything is absolutely fine.
What do you say?
On the way home, I checked the boost pressure.
I repeatedly accelerated in third gear, flooring the accelerator.
The boost pressure increases as usual, oscillates above 1.1 bar as always, and then settles at 0.9 bar at high engine speeds.
Perceived performance: Well, I think it could have been a bit better.
Exhaust fumes: Oh dear, the amount of smoke coming from the exhaust increases quadratically with the engine speed. At 4000 RPM, I can barely see anything through the rear window. It's really disgusting. The car has never smoked like this before.
I checked the crankcase ventilation system after the ride.
I unscrewed the hose that connects to the black container on the valve cover; there's a slight oil film inside. I think that's normal for a car with 230,000 km.
What I'm planning to do now:
- Da der Ladedruck passt denke ich nicht das es an einer undichten Verschlauchung zwischen Turbo und Saugrohr liegt. What do you think?
- I suspect it's either the nozzles or the HFM (High-Frequency Manifold).
Can I check the HFM (High-Flow Mixer)? For example, at a constant speed of 100 km/h and xyz RPM, approximately xyz kg/h should be measured. Or is there an adaptation value or something similar that I can use to determine something?
Regarding the oil leak:
It's definitely a leak from the crankcase ventilation hose connection. I cleaned everything thoroughly, and now, after a few kilometers, you can see that it's leaking out near the flange (see the picture above).
Until the days...
Markus.
Translated on 06-09-2026, 16:14.
Nebelwerfer_TDI
Post06-09-2006, 13:06    Subject: Engine Problems: Black, Smoking Crankcase Ventilation Quote
Regarding the exhaust: the EGR valve is stuck open. Solution: seal the EGR valve with a metal plate.
Regarding the oil leak: the lower connection of the KGE (turbocharger coolant expansion unit) is sealed with an O-ring, and it looks just like the quick-release couplings on the charge air ducts of newer TDIs. Solution: Pull out the clip, remove the pipe, and replace the O-ring with a new one.
Best regards, Nebelwerfer.
Translated on 06-09-2026, 16:18.
bastion
Karma: +6 / -1   Thank you, like it!
Post06-09-2006, 13:12    Subject: Engine Problems: Black, Smoking Crankcase Ventilation Quote
Due to the compression pressures. They are quite low. 19 bar is the minimum for your engine.
A4 Avant 08/01 AWX 05/08-
Translated on 06-09-2026, 16:19.
Nebelwerfer_TDI
Post06-09-2006, 13:24    Subject: Engine Problems: Black, Smoking Crankcase Ventilation Quote
Well, just look at his mileage. Other engines are often finished much sooner icon_rolleyes.gif.
bastion
Post06-09-2006, 13:29    Subject: Engine Problems: Black, Smoking Crankcase Ventilation Quote
"There are also engines that still have pressures exceeding 24 bar. Also, 230,000 km is only a moderate mileage for me."
Nebelwerfer_TDI
Post06-09-2006, 13:38    Subject: Engine Problems: Black, Smoking Crankcase Ventilation Quote
Also, for me, 230,000 km is just an average mileage.
With a reasonable driver.
Translated on 06-09-2026, 16:20.
MarkusAFN
Post06-09-2006, 14:37    Subject: 19bar iO niO: What is it? Quote
Thank you for the answers.
Die AGR werd ich mir heute oder morgen anschauen. I was actually planning to do that.
Regarding compression:
The values are listed above.
Who can tell me from a reliable source how much iO and niO are?
My VW mechanic said the AFN engine has a top-notch fuel pressure of 22 bar, and the lower limit is 16 bar. So, I'm still within the acceptable range.
Suddenly, they're talking about 24bar.
Does anyone have definitive values for this, or is that information available somewhere on the internet?
Thank you.
Hello.
Translated on 06-09-2026, 16:21.
bastion
Post06-09-2006, 14:41    Subject: Engine Problems: Black, Smoking Crankcase Ventilation Quote
As far as I know, 19 bar is the minimum. The 24 bar was just an example; there are also engines with 230,000 km that still have such a high compression ratio.
Translated on 06-09-2026, 16:22.
MarkusAFN
Post06-09-2006, 22:25    Subject: Engine Problems: Black, Smoking Crankcase Ventilation Quote
I just found my 'Ich helf mir selbst' book again after a long search.
It also states that the minimum pressure is 19 bar.
Maybe it's finally time to buy a new car after 6 years and 180,000 kilometers.
Putting money into a car/engine when a replacement engine might be needed soon doesn't really make sense.
Translated on 06-09-2026, 16:23.
BM
Avatar-BM
Post07-09-2006, 0:16    Subject: Engine Problems: Black, Smoking Crankcase Ventilation Quote
Can anyone tell me, from a reliable source, how much iO and niO there are?
My VW workshop said that the AFN has a top iO pressure of 22 bar, and the minimum acceptable pressure is 16 bar.
Who can confirm to you, from a reliable source, that the measuring device of the icon_biggrin.gif is accurate, or that it was measured correctly?
Given the very small pressure differences between the individual cylinders, I would cautiously assume that it might still be okay.
Depending on the volume of the air path from the ZK (control unit) to the measuring device (possibly with an adapter or similar in between), the compression ratio decreases accordingly, which means the actual compression pressure is higher than the measured pressure. Therefore, it is possible that your icon_biggrin.gif is correct, even though the wear limit is 19 bar.
3B5 AJM
Translated on 06-09-2026, 16:24.
Post07-09-2006, 9:34    Subject: Engine Problems: Black, Smoking Crankcase Ventilation Quote
How did you measure the boost pressure?
If the MSTG (presumably a pressure sensor) now has a faulty reading, displaying 1 bar, but the actual pressure is only 0.7 bar, it adjusts to the real value of 0.6 bar, which works perfectly with the VTG (presumably a control system). (These are hypothetical values.)
I can easily test my pressure sensor because it should produce at least 0.6 bar at 4000 units, which allows me to always calibrate and check if the sensor is still working.
Take a mechanical LDA.
Nozzles are also a good tip - and you'll always find a buyer for any 190 bar 205 nozzles you might have bought unnecessarily. The 1Z faction will laugh about it icon_smile.gif.
Translated on 06-09-2026, 16:26.
MarkusAFN
Post07-09-2006, 17:50    Subject: Engine Problems: Black, Smoking Crankcase Ventilation Quote
I measured the boost pressure using a mechanical VDO gauge. I've had it installed for years, ever since I had problems with the VTG adjustment.
I'm going to check the AGR today.
Until the days...
Translated on 06-09-2026, 16:27.
No new posts Frozen PCV Valve: AFN/AHU Engine Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A4, interior cools down too much Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Caddy 2K Engine: Black Smoke When Accelerating Diesel Engine Technology
New posts Audi 2.5 TDI VP44: Excessive Smoke? Dieselschrauber Bar
No new posts Passat 3B MBK: AFN Engine - Black Smoke Issues On-Board Diagnostics (OBD)
No new posts Crankcase Ventilation 1Z Diesel Engine Technology
