G3 TDI AHU: Best Starter Battery Options
Go to page: 1, 2  Next
bindpe
Karma: +5 / -2   Thank you, like it!
Post14-10-2006, 9:14    Subject: G3 TDI AHU: Best Starter Battery Options Quote
Hello.
Since my original battery, which is already 9 years old, started showing signs of weakness last winter, I'd like to get a new one.
Can you recommend a specific brand, or which batteries offer a good price-performance ratio?
Please share your experiences. Where do you buy your batteries?
Does it actually make a difference to choose a battery with a higher cold-cranking current? In accessory stores, they often try to sell you a battery with more amp-hours, but that doesn't really achieve anything, does it, unless you drive mostly short distances?
Thank you for your answers.
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 24-10-2026, 12:19.
Audi A4
Karma: +2 / -4   Thank you, like it!
Post14-10-2006, 10:10    Subject: G3 TDI AHU: Best Starter Battery Options Quote
The original VW LL batteries performed excellently in tests, but they are not the cheapest option.
Günther
Translated on 24-10-2026, 12:20.
pro
Post14-10-2006, 10:56    Subject: G3 TDI: Best Starter Battery for AHU Engine Quote
Which batteries offer a good price-performance ratio?
http://www.oeamtc.at/netautor/html_seiten/batterietest/batterietest_2004/gesamt.html
Translated on 24-10-2026, 12:21.
Audi A4
Post14-10-2006, 11:07    Subject: G3 TDI AHU: Best Starter Battery Options Quote
That confirms my opinion icon_lol.gif.
Post14-10-2006, 13:49    Subject: G3 TDI AHU: Best Starter Battery Options Quote
hi,
She is almost 11 years older than me.
She's managing now, but it will be tight if there's a hard frost.
If that happens, a genuine VW battery will be installed again, because the fact that this battery has been working for 11 years is quite valuable.
Translated on 24-10-2026, 12:22.
Post14-10-2006, 18:11    Subject: G3 TDI Starter Battery: Best Options & Reviews Quote
bindpe wrote:
Does it actually make a difference to choose a battery with a higher cold cranking current?
In the accessory trade, they always try to sell you a battery with more AH, but that doesn't really achieve anything, except maybe if you drive a lot of short distances? }
"Yes, definitely pay attention to the cold-cranking current! Last fall, I bought a (admittedly: inexpensive) 55Ah battery with approximately 280A cold-cranking current and used it in my G3 AHU. Then, during a period of extreme frost, I bought a brand-name battery (Bosch) with approximately 52Ah and nearly 600A cold-cranking current."
The 280A battery, even when fully charged, couldn't bring the cooled-down engine up to sufficient speed in extremely cold temperatures. With the new battery, which had a higher cold-cranking current, I haven't had any problems, even though it had a slightly lower capacity.
The exchange of the cheap battery was also not possible, as the manufacturer stated that it was within the specifications. However, it was completely unsuitable for modern diesel engines. I had initially thought it would be sufficient, and I chose it because of the features like the auxiliary heater, many standby consumers, and the price compared to batteries with higher capacity, but in the end, I ended up paying twice.
Conclusion: Having a large battery capacity is beneficial if you have features like a parking heater or many devices that consume power in standby mode, especially if the vehicle has long periods of inactivity. However, in our TDIs, a high current draw is required at low temperatures.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 24-10-2026, 12:24.
Post14-10-2006, 19:42    Subject: G3 TDI AHU: Best Starter Battery Options Quote
Now we come to the familiar problem that there are two different methods for measuring cold loss.
And that's where the results differ quite significantly.
I suspect that the 280 A and 600 A values are simply the results of two different measurements. It's unlikely that two batteries could be that different.
m
Translated on 24-10-2026, 12:27.
golf3schrauber
Post15-10-2006, 18:23    Subject: G3 TDI AHU: Best Starter Battery Options Quote
At the very first moment of starting, the full cold current (the battery's short-circuit current) flows through the starter motor.
Isn't it also dangerous to significantly increase that current? I'm thinking about the lifespan of the starter motor. One would assume that someone considered the battery's power output when choosing it for the engine.
I also face this moral dilemma every time I have to choose the battery size.
Gruss Oliver.
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 24-10-2026, 12:28.
Post15-10-2006, 18:31    Subject: G3 TDI AHU: Best Starter Battery Options Quote
Ouch.
Sorry, Oliver, but your question shows that you don't know everything about electricity.
You can start your Golf with a 61 Ah battery (like the standard battery for TDI models), or with a battery of any other capacity, even a very large one like 29386349086239048629846 Ah.
If the 61 is new, you won't notice a difference of even 0.0.
While the other one could technically get you all the way from Munich to Berlin, the starter motor would be completely ruined.
Imagine this:
You have a tank with 61 liters of water and a hose (cable) attached to a brush (starter).
The water comes out exactly the same, as if the tank held millions of liters (at the same height!). The brush or valve regulates the flow.
The current is measured in amperes, the duration is measured in hours, and the distance is measured in volts.
However, if your million liters of water are under immense pressure (many volts), the car wash brush will blast a hole in the paint, or the hose will burst.
But all batteries have 12 volts icon_smile.gif.
Translated on 24-10-2026, 12:30.
Audi A4
Post15-10-2006, 18:55    Subject: G3 TDI AHU: Best Starter Battery Options Quote
Another comparison: a 0.33-liter beer bottle and an 80-liter keg.
You can drain both to "get it started" (start the engine).
In a battery with insufficient "cold current" (equivalent to a 0.33-liter beer bottle), the motor will not...
Start it, and you'll stay sober.
When you connect the battery to the starter motor, it will "kick in," meaning the motor will start because the battery is providing enough power.
We can supply spark plugs, and also starters.
Translated on 24-10-2026, 12:33.
Post15-10-2006, 19:08    Subject: G3 TDI AHU: Best Starter Battery Options Quote
I overlooked this ominous Kaelstrom (as I have already explained).
I equated the question about the battery size with the "capacity," which is the Ah number.
@ Oliver:
If you don't have anything specific in mind for the battery, just install a 61Ah VW battery; it's that simple.
The 1Z model with air conditioning might have had a larger one [referring to a component, likely a battery or engine].
Translated on 24-10-2026, 12:34.
Audi A4
Post15-10-2006, 19:15    Subject: G3 TDI AHU: Best Starter Battery Options Quote
"Battery size" is already the "Ah number"; "power-to-weight ratio" is then the "cold current"! icon_lol.gif icon_lol.gif icon_lol.gif
Translated on 24-10-2026, 12:35.
ollli
Post21-10-2006, 14:23    Subject: SEO-Optimized Website Design: Tips & Tricks Quote
Hello.
I had a 63 Ah battery in my Golf 2 for several years and replaced it with a 74 Ah battery. The 74 Ah battery is 1-2 cm larger than the 63 Ah one. I thought having a bit more capacity would be beneficial.
The capacity is ideal for large Hi-Fi systems. The price was almost the same as the 63 model.
Olli.
Translated on 24-10-2026, 12:36.
Post29-10-2006, 12:30    Subject: G3 TDI AHU: Best Starter Battery Options Quote
Okay,
My battery finally gave up, almost exactly 11 years after it was manufactured.
After being in place for 1-2 weeks, it stopped working yesterday.
However, the Leon, which was idling, provided enough power to jump-start the car. After 130 kilometers and a few hours of being stationary, it started again, but not very well.
Okay, so there's a new VW 61 Ah battery arriving tomorrow.
Translated on 24-10-2026, 12:38.
tdi-schrauber
Post30-10-2006, 12:12    Subject: G3 TDI AHU: Best Starter Battery Options Quote
Hello!
I can wholeheartedly recommend Optima batteries (especially Optima Yellow).
The relatively low capacity of 55Ah might seem discouraging, however, the typical "diesel battery" only achieves a high capacity due to its large surface area of plates.
The large surface area is necessary for the high inrush current.
Considering that an hour of heating can consume a maximum of 15-20Ah, even a 55Ah battery is not a problem. Because Optima batteries maintain their power delivery even when partially charged, the subsequent starting process is not only possible, but even better than with the original battery. The design as a cycle battery is a significant advantage in this case (lifespan).
Even in short-distance operation, the charging performance of these batteries is very good, and their ability to accept current is much higher than that of conventional batteries.
Therefore, we equip all vehicles that have a parking heater with these batteries.
The initial purchase price, which may seem high at first glance, is offset over time. The Optima battery lasts at least twice as long as a conventional battery when used in cycling mode.
There is one drawback: the connection terminals do not conform to German standards, so a slight modification of the connection cables may be necessary.
BYE
TDI mechanic.
Translated on 24-10-2026, 12:40.
Post30-10-2006, 17:36    Subject: G3 TDI AHU: Best Starter Battery Options Quote
Over 22 years?
I don't need it icon_smile.gif.
Translated on 24-10-2026, 12:42.
No new posts Exide AGM Starter Battery Electrical Systems, Vehicle Electronics, Multimedia
No new posts Boost Gauge: Which One Is Right? Diesel Engine Technology
No new posts O2 Sensor for V6 TDI 3.0/2.7: Which one? Diesel Engine Technology
No new posts What oil viscosity? Diesel Engine Technology
