TDI Engine Problems: Causes and Solutions
Dieselmike
Post04-12-2006, 11:15    Subject: TDI Engine Problems: Causes and Solutions Quote
I've been giving this some thought. Since I have to wait 30 seconds every morning after starting the engine for the oil to reach the valve lifters, I came up with the following idea.
What if a plunger is not properly lubricated with oil, and as a result, the valves do not open correctly? icon_question.gif
Best, Mike.
Translated on 28-08-2026, 19:04.
neubaupe
Post04-12-2006, 12:52    Subject: TDI Engine Problems: Causes and Solutions Quote
It is definitely not normal for oil not to have reached the camshaft 30 seconds after the engine start.
If the valves fail to open within the specified tolerances, it's usually due to...
related to the current oil supply.
Best regards.
Peter.
Translated on 28-08-2026, 19:05.
Dieselmike
Post14-12-2006, 10:30    Subject: TDI Engine Problems: Causes and Solutions Quote
Whether this is normal or not, we'll leave that aside for now. The question is, is this possible during operation?
Translated on 28-08-2026, 19:06.
Herr Antje
Post14-12-2006, 10:49    Subject: TDI Engine Problems: Causes and Solutions Quote
poorer gas exchange. What exactly do you want to know? It's obvious that the valves aren't opening completely, right? In addition, the valves are opening later and closing sooner.
Either your hydraulic system is failing, or your oil pump is failing. 30 seconds is too long. If it's happening while driving, the hydraulic system is likely very damaged. Usually, a failing hydraulic system starts having "problems" immediately after starting.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 28-08-2026, 19:07.
No new posts Misfires on 2.0 TDI engine, rough running Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts New solution for unstable idle AXR Diesel Engine Technology
No new posts Chassis Theory: Understanding Vehicle Suspension Transmission, Chassis, Body & Interior
No new posts VP 37 Engine: Theory of Age-Related Issues Diesel Engine Technology
No new posts Theory of creeping performance loss in TDI engines Diesel Engine Technology
