BOSCH MAF Sensor Connector - Part Number
Post25-08-2005, 11:05    Subject: BOSCH MAF Sensor Connector - Part Number Quote
I need the part number of the connector and the contacts used in the Bosch mass airflow sensor.
I already have that information for the Pierburg.
/viewtopic.php?t=6993&highlight=connector+lmm
"Thank you."
Translated on 22-10-2026, 4:44.
MagicSven
Post31-08-2005, 13:26    Subject: BOSCH MAF Sensor Connector - Part Number Quote
Part No.: 1J0-973-775-A
Occupancy:
1 TF (Option)
2. Battery voltage (Ubat)
3 servings.
4. Reference voltage Uref
5 UA (output signal)
Translated on 22-10-2026, 4:45.
Post31-08-2005, 14:09    Subject: BOSCH MAF Sensor Connector - Part Number Quote
Thank you very much.
By "contacts," I meant the yellow cable sections with the pre-crimped connectors.
If you have that one too, that would be perfect.
"Thank you."
Translated on 22-10-2026, 4:46.
Post31-08-2005, 14:18    Subject: BOSCH MAF Sensor Connector - Part Number Quote
Sorry, the number refers to the connector that is connected _TO_ the MAF sensor.
I need whatever connects to this plug.
Pierburg offers this part for the 1Z, AFN, AHU, and ALE engines.
/viewtopic.php?t=6993&highlight=lmm+connector
Translated on 22-10-2026, 4:47.
No new posts Explanation of the VAG part number Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Pressure Sensor Connector: Find Part Number 1J0906627A Diesel Engine Technology
No new posts BOSCH Injector Pump Settings: Calibration Values Diesel Engine Technology
No new posts BOSCH VP Assembly: Questions & Answers Diesel Engine Technology
No new posts Bosch Auto Parts Catalog Online Diesel Engine Technology
