Measurement blocks A6 2.5 TDI V6
scott1402
Post20-10-2002, 12:21    Subject: Measurement blocks A6 2.5 TDI V6 Quote
'Does anyone have a list of measurement block IDs for VAG-COM and the Audi A6 2.5 TDI V6?'
or can you tell me where I can find the measurement block for the intake air temperature and what it normally looks like?
Translated on 15-07-2026, 16:09.
avoso
Post21-10-2002, 11:49    Subject: Measurement blocks A6 2.5 TDI V6 Quote
Check out the 'Error Database' section.
You'll find it there, under the engine identification label, which will be either AFB or AKN if you have the 150hp TDI engine!
Best regards, Achim.
Translated on 15-07-2026, 16:10.
No new posts VE Injection Pump Data: 5-Cylinder Engine Performance Technical Data
No new posts VE Injection Pump Data: 4-Cylinder Engine Performance Technical Data
No new posts PD Injector Data: 4-Cylinder Engine Performance Technical Data
No new posts Messwertblöcke G60? Diesel Engine Technology
No new posts Measurement blocks 1Z On-Board Diagnostics (OBD)
No new posts Measurement blocks On-Board Diagnostics (OBD)
No new posts Measurement values into EDC measurement blocks On-Board Diagnostics (OBD)
