Central locking malfunction
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Zimbo30
Post01-10-2006, 16:18    Subject: Central locking malfunction Quote
I'm having a problem. When I close the doors on my 1999 Passat 3B TDI (regardless of whether I use the key or the remote), all the doors lock, but the driver's door handle still protrudes slightly. However, the door remains locked. I have read out the error codes and I am seeing the following error:
00928 - Locking Unit for Central Locking, Driver's Side (F220)
27-00 - Unlikely Signal
Are these the microswitches, or what else could it be? Does anyone have an idea?
Best regards, Dirk
DariusPolo
Post01-10-2006, 19:19    Subject: Central locking malfunction Translating...
[Translating...]...gebrochener Kabelbaum (bekanter problem bei Passat)
Darius
Zimbo30
Post01-10-2006, 19:40    Subject: Central locking malfunction Translating...
[Translating...]
erstmal danke für die Antwort.
Und wo ist er gebrochen? In der Tür?
Gruss Dirk
mullemaus
Post01-10-2006, 20:49    Subject: Central locking malfunction Translating...
[Translating...]Es kann der Microschalter sein, oder ein Kabelbruch. Meist im Türbalg, einfach mal abziehen und nachsehen icon_wink.gif
No new posts Customization options for Volkswagen central locking systems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Central Locking Adjustment Options Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts fehler 462 d... On-Board Diagnostics (OBD)
No new posts Non-erasable fault code door control Passat 3C On-Board Diagnostics (OBD)
No new posts Startproblem 1Z Motor fehler gefunden Diesel Engine Technology
No new posts Airbag control unit, 2001 model, error code 65535 Diesel Engine Technology
