tom_
Joined: 10/01/2006 Posts: 1 Karma: +0 / -0 Location: München
01-10-2006, 10:59 Subject: VAG-COM: Diagnose system features and capabilities. |
Hello.
I am interested in the semi-professional EOBD/OBD2 KKL diagnostic system from the online store.
Car: Audi TT 8N Coupe Fronti 190 HP, model year 2006, but it's still the first generation (and it's not a diesel either) .
I have already reviewed Ross-Tech.com and used the search function here in the forum, but I still have a lot of questions about it.
Ross-Tech states what is possible with the 8N model:
01 Engine: Yes
02 Automatic Transmission Y (If equipped)
03 ABS Brakes Y
08 HVAC Y (If equipped) <-- what is HVAC?
09 Electrical Control No <-- which systems are these?
0F Digital Radio Y (If equipped)
14 Suspension Electronics N
15 airbags.
16 Steering Wheel N <-- and the steering angle sensor for ESP?
17 instruments.
19 CAN Gateway N
22 All-Wheel Drive Y (If equipped)
25 Immobilizer Y (If equipped, as of 2001 in the US, integrated with the instrument cluster and located at address 17).
35 Central Locks Y.
37 Navigation Y (If equipped) Y
42 Door Electric, Driver Side.
44 Steering Assist N
45 Interior Monitor Y (If equipped)
46 Central Convenience N.
47 Sound System N.
4C Tire Pressure Monitoring System II.
52 Door Elect, Pass N.
55 Headlight Range Y (If equipped)
56 Radio Y
75 Telematics N
76 Park Assist Y (If equipped)
77 Telephone Y
Are the following tests/adjustments compatible with the semi-professional diagnostic system EOBD/OBD2 KKL?
Possible?
If anyone takes the time to read and respond:
Would the following be sufficient: everything yes, except for 10, 14, and 18 (this was just an example)?
Thank you in advance!
Airbag: Query and clear fault memory.
2. Airbag: Actuator diagnosis.
Central locking system: Query and clear error codes.
4. Central locking system: Code the control unit and read the sensor data block.
5. Climate control system: Query and clear fault memory.
6. Climate control system: Actuator diagnosis and basic settings.
7 Climate control system: Reading measurement data block.
"Program/code a new combination instrument after contacting VAG to obtain the PIN."
9 Steuergeräteidentifikation Kombiinstrument (zeigt u.a. Operating number:
10 Steuergeräteidentifikation Wegfahrsperre (zeigt u.a. Chassis number:
11 Combination instrument: Query and clear fault memory.
12 Combination instrument: Reading the measured value display.
13 Combination instrument: Adjust settings, e.g., increase the fuel consumption display by a few percent.
14. Immobilizer: Check and clear error codes.
15 Immobilizer: Read measurement block.
"Programmed 16 keys after confirming the PIN with VAG."
"Program 17 new or used engine control units after checking the PIN with VAG."
18 ABS: Recode the new control unit.
19. Vent the ABS system when the piping is initially empty.
20. ABS: Check and clear fault memory.
21. ABS: Read actuator diagnostics and measurement data block.
22. ABS: Login procedure for zero-balancing <-- important
23; ABS: Calibrate steering angle sensor and lateral acceleration sensor.
24. Radio: Query and clear error memory.
25. Radio: Encode control unit.
26. Radio: Adjust settings, e.g., configure external tuners for DAB.
27. Motronic: Query and clear error codes.
28. Motronic: Actuator diagnostics and basic settings.
29: Motronic: Calibrating the throttle valve.
30 Motronic: Encoding a new control unit.
31: Motronic: Calibrating the lambda sensor.
32: Motronic: Read measurement data block, e.g., check speed.
33. Generate readiness code.
34. Headlight beam adjustment: Check and clear fault memory.
35. Headlight beam adjustment: Actuator diagnosis and basic setting.
36. Headlight beam adjustment: Code the control unit.
Translated on 12-08-2026, 0:02.
Ross-Tech-Support Profi-Schrauber
01-10-2006, 12:00 Subject: VAG-COM: What can this diagnostic system do? |
tom_ wrote: | | 08 HVAC Y (If equipped) <-- what is HVAC? |
Climate control system (also known as Climatronic).
tom_ wrote: | | 09 Electrical Control No <-- which systems are these? |
Only the new TT features an on-board network.
tom_ wrote: | | 16 Steering Wheel N <-- and the steering angle sensor for ESP? |
The steering column electronics are only installed in newer models or vehicles with multifunction steering wheels.
tom_ wrote: | 1. Airbag: Query and clear fault memory.
14 Immobilizer: Read and clear error codes.
22. ABS: Login procedure for zero-balancing synchronization <-- important.
36. Headlight beam adjustment: Code the control unit | .
Yes.
Translated on 12-08-2026, 0:15.
Jochen_145 Guest
01-10-2006, 20:25 Subject: VAG-COM: What can this diagnostic system do? |
If that is the intended meaning, then it is technically not entirely correct from a ROSS-tech perspective.
HVAC stands for Heating Ventialtion Air Combination and refers to the 'box' that houses the heat exchangers, the fan, and the dampers used for heating/cooling air and redirecting it.
The climate control system (which can only be called 'Climatronic' if it is manufactured by BHTC, but has generally become known by that name) is actually the CCU, ClimatControl Unit.
Translated on 12-08-2026, 0:22.
01-10-2006, 20:29 Subject: VAG-COM: Diagnose system features and capabilities. |
Thank you for the clarification, Jochen. Although the term used was specific to the vehicle of the person who made the inquiry, it's worth noting that in the TT, the heating system (if not equipped with air conditioning) cannot be diagnosed.
Translated on 12-08-2026, 0:24.
