Intake Manifold Vacuum Leak to Ground
Marv
Post01-10-2006, 21:53    Subject: Intake Manifold Vacuum Leak to Ground Quote
Evening everyone,
'The error code in the fault memory is '17564 G71: Short circuit to ground'.'
There, the consequences are also listed. Among them is 'loss of performance.'
For me (ARL), it even goes into emergency mode. Is that correct?
'Just asking because it's not listed under 'consequences,' or could it be something else?'
'MFG Marv'
This is a common German abbreviation that stands for 'Mit freundlichen Grüßen,' which means 'Sincerely' or 'Best regards.' It is often used in emails and letters.
Translated on 28-10-2026, 13:58.
Post02-10-2006, 7:52    Subject: Intake Manifold Vacuum Leak to Ground Quote
Hi Marv,
You should really have your "lab coat" status revoked immediately...
What do you think the engine control unit (ECU) should do if it can no longer determine the boost pressure produced by the turbocharger?
Translated on 28-10-2026, 13:59.
No new posts Error code 005399 / P1517 - Short circuit to ground Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts KEY-USB Interface Failure: Short to Ground? On-Board Diagnostics (OBD)
No new posts Lambda Sensor (G39): Short to Positive On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Short Circuit Error 004160: Solved! Diesel Engine Technology
No new posts Terminal 58d - Short circuit to ground Electrical Systems, Vehicle Electronics, Multimedia
