Central Locking Error: Troubleshooting Guide
Zimbo30
Post01-10-2006, 15:18    Subject: Central Locking Error: Troubleshooting Guide Quote
I'm having the following problem. When I lock the doors on my Passat 3B TDI, manufactured in 1999, whether with the key or the remote, all the doors lock, but the button on the driver's side door pops out slightly. The door remains locked, however. I read the error memory, and the following error is displayed:
00928 - Driver's side central locking control unit (F220)
27-00 - implausible signal.
Sind das die Mikroschalter oder was könnte es sein. Does anyone have a clue?
Best regards, Dirk.
Translated on 31-08-2026, 10:25.
DariusPolo
Post01-10-2006, 18:19    Subject: Central Locking Error: Troubleshooting Guide Quote
...broken wiring harness (a known problem with the Passat).
Darius.
Translated on 31-08-2026, 10:26.
Zimbo30
Post01-10-2006, 18:40    Subject: Central Locking Error: Troubleshooting Guide Quote
First of all, thank you for the response.
Und wo ist er gebrochen? In the door?
Best regards, Dirk.
Translated on 31-08-2026, 10:27.
mullemaus
Post01-10-2006, 19:49    Subject: Central Locking Error: Troubleshooting Guide Quote
It could be the microswitch, or a broken cable. Most often, it's located in the door bellows; just unplug it and take a look icon_wink.gif.
No new posts Customization options for Volkswagen central locking systems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Central Locking Adjustment Options Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error 462: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts Non-erasable fault code door control Passat 3C On-Board Diagnostics (OBD)
No new posts 1Z Engine Start Problem: Fault Found Diesel Engine Technology
No new posts Airbag Control Unit, MJ2001, Error 65535 Diesel Engine Technology
