GSK Shares Traded: Analysis & Trends
Post09-02-2006, 22:04    Subject: GSK Shares Traded: Analysis & Trends Quote
Yesterday I replaced glow plug Zyl4, and today I replaced the remaining three.
I'm surprised that "verrúst" translates to two and "sauber" translates to two.
Cylinders 1 and 3 look clean, while the cylinders in the straight line are dirty.
Can someone explain this?
 File size:  62.82 KB
 Viewed:  1809 times
Translated on 21-08-2026, 22:00.
Post09-02-2006, 22:08    Subject: GSK Exchange: Details & How-To Guide Quote
dieselmartin wrote:
Cylinders 1 and 3 look clean, while the even-numbered cylinders are dirty.
Are the blackened candles coincidentally also electrically defective?
Translated on 21-08-2026, 22:01.
Post09-02-2006, 22:57    Subject: GSK Shares Traded: Analysis & Trends Quote
So, initially (about a week ago), only the Z4 was defective.
Inzwischen kann ich aufm Schriebtisch nur noch an Z3 einen Widerstand messen, alle anderen haben unendl. Ohm.
But yes, that would be a good fit for it.
I'm going to plug in the charger now, let's see what happens...
Translated on 21-08-2026, 22:02.
Post09-02-2006, 23:04    Subject: GSK Shares Traded: Analysis & Trends Quote
Okay.
Only the third one is still intact. That explains why the second and fourth ones are damaged.
It seems that person recently passed away.
Then, even with just two candles, it still started up really well icon_smile.gif.
Thank you, Ulf.
Translated on 21-08-2026, 22:03.
Post10-02-2006, 9:08    Subject: GSK Shares Traded: Analysis & Trends Quote
dieselmartin wrote:
only the third one is still working properly.
Now I'm also interested (for my "back of my head" statistics icon_razz.gif) in knowing how many miles the candles have been used for.
Based on what I can see in the photo, there doesn't appear to be any significant damage or melting at the tips... ?
Post10-02-2006, 12:15    Subject: GSK Shares Traded: Analysis & Trends Quote
This morning, he started off really well icon_smile.gif.
It was immediately ignited and turned up very high.
Does the Electronic Control Unit (ECU) have a learning algorithm for the initial fuel quantity?
Something like, "I've had a bad reaction the last 5 times I took 20mg, so now I'm trying 25mg."
Then she should get used to the new candles icon_smile.gif.
The number 4 is slightly bent at the top, but the others are fine.
I bought the vehicle with 124,000 km on the odometer, and I haven't changed the spark plugs since then (until last night, when it had 208,000 km).
Since all four spark plugs still have the old Bosch part number ...009 (now I have ...022), and they are identical, it's possible that these are the original ones.
Translated on 21-08-2026, 22:05.
Post26-10-2006, 23:12    Subject: GSK Shares Traded: Analysis & Trends Quote
On the Leon (ASV), we had three faulty spark plugs after 96,000 kilometers.
I don't know if they are the first ones. However, at least 2 threads are quite damaged - and this was BEFORE I unscrewed the candles icon_evil.gif.
Translated on 21-08-2026, 22:07.
Post27-10-2006, 13:51    Subject: GSK Shares Traded: Analysis & Trends Quote
dieselmartin wrote:
On the Leon (ASV), we had three defective spark plugs after 96,000 km.
It likely happens even after "warm" starts, due to prolonged afterglow. That's what our ALH Ibiza is doing, anyway.
It seems like the fuse somehow isn't handling things very well: every spring, it develops contact problems that last for about half a year.
Translated on 21-08-2026, 22:08.
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post27-10-2006, 22:42    Subject: GSK Shares Traded: Analysis & Trends Quote
Hello.
"What exactly is written in the error memory, for example, in a Golf 4, when spark plugs are defective? Or do you simply need to check the spark plugs with an ohmmeter? If they have resistance, everything is fine; if not, they are bad. Should all four spark plugs be replaced at once, or can they be replaced individually?"
"MFG" stands for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English. It is a common way to end a formal letter or email.
Audi SQ5 8R Cvub
Translated on 21-08-2026, 22:09.
Back to top Profile PM Email
Kuhni
Post28-10-2006, 3:36    Subject: GSK Shares Traded: Analysis & Trends Quote
Hello.
...deleted...
Best regards.
/viewtopic.php?t=13833
No comment.
Kuhni.
Translated on 21-08-2026, 22:10.
No new posts Zylinderkopf AFN getauscht! Diesel Engine Technology
No new posts Unterdruckdose getauscht Upload
No new posts ESP Replacement: LM/Fuel Injector Issues? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Speedometer replaced - engine won't start? Diesel Engine Technology
