AKF Diagnosis: Ignition Sequence Explained
Rick78
Post30-10-2006, 20:15    Subject: AKF Diagnosis: Ignition Sequence Explained Quote
Hello!
I need a little help with the 3.3 TDI AKF engine because I don't have the complete repair manual.
Can someone please tell me what the firing order is for the AKF engine?
I have read chapters 13 and 14 of the MWB.
http://www.harmoniedesoleuvre.lu/AudiA8/MWB_13_14_log1.xls
Der Diagnose nach zu urteilen müsste die Einspritzdüse (ED) des Zylinder 4 defekt sein, da konstant +2,49mg/H geregelt wird. ED 5 könnte von ED 4 beeinflusst werden wenn Zylinder 5 in der Zündreihenfolge vor Zylinder 4 liegt. LieAm I in the right place?
What is your opinion on the Audi regulation to replace all injectors? I plan to only replace the faulty injector and clean the remaining 7 with a special cleaner from BG Products.
Thank you in advance for any advice!
Raoul.
Translated on 20-08-2026, 17:26.
vagtuning
Post30-10-2006, 21:09    Subject: AKF Diagnosis: Ignition Sequence Explained Quote
Sequence: 1-5-4-8-6-3-7-2
Translated on 20-08-2026, 17:28.
Rick78
Post30-10-2006, 21:27    Subject: AKF Diagnosis: Ignition Sequence Explained Quote
Thank you very much! That sounds perfect!
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
No new posts OBD2 Diagnostics for Non-Diagnostic CAN Bus On-Board Diagnostics (OBD)
No new posts Diagnosis On-Board Diagnostics (OBD)
No new posts KKL/KL Diagnosis: Causes & Treatment Diesel Engine Technology
No new posts VAG Diagnostics: Troubleshooting & Repair On-Board Diagnostics (OBD)
