Automatic Transmission Control Module Coding AFN
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Soaring77
Post24-01-2006, 21:07    Subject: Automatic Transmission Control Module Coding AFN Quote
Hello forum,
I recently purchased an AFN automatic transmission that I would like to install in my Passat with an AHU engine. However, I want to keep my existing manual transmission. I would like to know if it is possible to reprogram the AFN automatic transmission control unit to work with a manual transmission, and if so, how to do it?
Can you help me?
Thank you in advance.
Peter.
Translated on 17-09-2026, 10:50.
Ross-Tech-Support
Post24-01-2006, 22:48    Subject: Automatic Transmission Control Module Coding AFN Quote
Part numbers of the two control units?
Translated on 17-09-2026, 10:51.
[email protected]
Post01-04-2006, 0:44    Subject: Automatic Transmission Control Module Coding AFN Quote
"Actually, it's not a problem. Just program channel 07 to 000001 and you're done. If that doesn't work, write back and I'll take another look. There should also be something at the beginning, like 'sg00', or call me again if the problem persists. Best regards, Bernd, 01702305097."
Back to top Profile PM Email
Rudi
Post01-04-2006, 12:08    Subject: Automatic Transmission Control Module Coding AFN Quote
Hello Bernd,
'I wouldn't call it 'Channel 7' icon_cool.gif.'
VAG-COM and other testers have a function with the number 7 - the 'Coding' function.
If it's a standard AFN (Airbag Control Unit), the following codings might be possible with the control unit:
00001 Automatic.
00002 Manual transmission.
00003 Manual transmission, all-wheel drive.
The 021DF (AFN Golf3) can only support codes 00001 and 00002, for example.
@Peter
If you want to be sure which codings your AFN ECU has,
Please provide the part number.
Rudi
Translated on 17-09-2026, 10:53.
[email protected]
Post02-04-2006, 22:00    Subject: Automatic Transmission Control Module Coding AFN Quote
Okay, I only did it once, so I don't remember exactly. But you're probably right. The question was whether it could be programmed for automatic or manual, right? But it also says at the beginning when you access the control unit: 028 906 021GN 1.9L R4 EDC G00SG. I think the "00" indicates manual, and if it's "01", it's for automatic. Please correct me if I'm wrong. As I said, I only did it once. Best regards, Bernd.
Translated on 17-09-2026, 10:54.
Rudi
Post02-04-2006, 22:07    Subject: Automatic Transmission Control Module Coding AFN Quote
'The '00' indicates that the control unit has not detected any internal errors (RAM, EEPROM, etc.).'
'SG' stands for Schalt-Getriebe (which is a manual transmission, but used in the context of automatic transmissions by company AG icon_wink.gif).
'Reprogramming is possible for many ECUs, but not all. Some have limitations.'
einen SG oder AG Block. That's all.
Rudi
Translated on 17-09-2026, 10:55.
neubaupe
Post16-10-2006, 20:08    Subject: Automatic Transmission Control Module Coding AFN Quote
000001program and done. If it doesn't work, just write again.
Just now, I wanted to change the transmission control unit (TCU) from manual to automatic on my 1998 VW Golf with a 1.9 TDI engine (AFN).
recode. For example, change 00002 to 00001. After I click 'encode!', it starts working.
The program runs, but it still displays the encoding '00002'.
Here are the data from my engine control unit (ECU) according to VAG-COM.
VAG Number: 028 906 021 EK
Encoding: 00002
Engine Control Unit (ECU) 1.9L R4 EDC G00SG 1438.
Workshop ID: WSC 06402.
Please don't tell me that this TCU only has one block for manual transmissions.
Evtl. muss ich mich zuerst einloggen ? How?
Thank you in advance & best regards.
peter
EDIT
Just received the original control unit (with a faulty turbocharger pressure sensor control).
connected, and tried to recompile it. No success, same symptoms.
VAG number: 028 906 021 EK.
Encoding 00002.
Workshop ID: WSC 16707.
Thank you & best regards.
peter
Translated on 17-09-2026, 10:58.
Rudi
Post16-10-2006, 22:10    Subject: Automatic Transmission Control Module Coding AFN Quote
Hello Peter, the 021EK only has one block - and that block is for SG icon_sad.gif.
Rudi.
Translated on 17-09-2026, 11:00.
neubaupe
Post17-10-2006, 9:04    Subject: Automatic Transmission Control Module Coding AFN Quote
Without using a search engine:
Can a STG (Selective Transfer Gear) with 2 blocks be installed in an AFN (presumably a vehicle model)?
(which is still cheaper than chip tuning)
Does an AFN driver really have nothing left to do, and has to go back under the hood to deal with some cables again?
snips. *He wonders why he bought/built the diagnostic adapter.* new_cry.gif
Best regards.
peter
Translated on 17-09-2026, 11:02.
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission Problems: Audi A4 01N AFN General Tips
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission AFN: Gearbox-Axle Assembly Oil Cha... Diesel Engine Technology
No new posts Automatic Transmission Coding: A6 C4 AEL On-Board Diagnostics (OBD)
No new posts Automatic Transmission Repair: VW Passat 1.9 TDI Diesel Engine Technology
No new posts Zeitweise starke Quitschgeräusche beim Automatik Getriebe Diesel Engine Technology
