Coilover Suspension Adjustment Guide
ollli
Post19-10-2006, 16:43    Subject: Coilover Suspension Adjustment Guide Quote
Hello, diesel mechanics.
I had a Koni adjustable coilover suspension installed in my Golf 2 CL (back when the currency was the Deutsche Mark). However, I'm a bit unsure about the adjustment. On the front axle, the suspension can be adjusted with a threaded mechanism. How do I know that both sides are adjusted equally? Should I count the thread rotations? Should I measure something?
Sure, I'd be happy to help. Please provide the text you would like me to translate from German to English.
Olli.
Translated on 07-10-2026, 3:44.
BM
Avatar-BM
Post19-10-2006, 22:04    Subject: Coilover Suspension Adjustment Guide Quote
How do I know that both sides are set to the same value? Do I count the threads? Do I measure?
The only way to do it correctly is with a scale, which is used to determine the individual wheel loads.
It should be possible to adjust these settings accordingly. When doing so, it is important to ensure that the vehicle is on a level and horizontal surface, and that the tires and tire pressure are the same on each axle.
3B5 AJM
Translated on 07-10-2026, 3:46.
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Adjust Coilover Suspension: How-To Guide Transmission, Chassis, Body & Interior
No new posts Do threaded suspension kits require wheel alignment after... Transmission, Chassis, Body & Interior
No new posts Einbau Koni Fahrwerk beim VW Bora 85KW TDI PD (AJM) Transmission, Chassis, Body & Interior
No new posts Bilstein B16 PSS 9 Gewindefahrwerk Vertriebshändler? Transmission, Chassis, Body & Interior
