Is the MWB13 indicator always a sign of worn injectors?
New Topic 🔒 Locked 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
elcapitano2000
Post24-10-2006, 21:50    Subject: Is the MWB13 indicator always a sign of worn injectors? Quote
Hello everyone,
I know that there has already been a lot of discussion and writing on this topic, but I still have a question (even though I've been reading through the old posts for quite some time).
Is it possible to have worn fuel injectors but not see any significant correction values in the engine control module (ECM)? In my case, everything seems to be within the acceptable range.
I have a 1998 Volkswagen Golf III with a 66 kW ALE engine. It has 230,000 km on the odometer and these are the original injectors.
I'm noticing a slightly increased fuel consumption (around 6.3-6.5 liters per 100 km) and I have the impression that the car simply doesn't accelerate as well as it used to.
However, I have to say that I've been driving mostly shorter distances lately, and I haven't been pushing the engine to its limits.
It would be great if someone could comment on this. The question is whether it's worth replacing the nozzles. It's not a cheap fix, and who knows how long the rest of the system will last.
Greetings.
El Capitan.
Translated on 20-07-2026, 14:34.
elcapitano2000
Post24-10-2006, 22:02    Subject: Is the MWB13 indicator always a sign of worn injectors? Translating...
[Translating...]
uppsss...da hab' ich 2 Stunden in den alten Postings gekramt und nicht bemerkt, dass es hier: https://community.dieselschrauber.org/en/viewtopic.php?t=13694 gerde erst beantwortet wurde.
Meine Frage nach der Rentabilität nach eurer Einschätzuung würd mich trotzdem noch interessieren.
No new posts Replacement of injector nozzles/holders on a VP-TDI Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Aussagekraft des MWB13 oberhalb der Leerlaufdrehzahl? Diesel Engine Technology
No new posts Kurbelwellenschraube beim AFN IMMER tauschen? Diesel Engine Technology
No new posts KG Druck as an indicator of engine defect? Diesel Engine Technology
No new posts Exhaust Temp: Engine Load Indicator? Diesel Engine Technology
