MWB13: Always an Indicator of Worn Injectors?
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
elcapitano2000
Post24-10-2006, 20:50    Subject: MWB13: Always an Indicator of Worn Injectors? Quote
Hello everyone,
I know that there has already been a lot of discussion and writing on this topic, but one question still remains for me (even though I've been browsing through the old posts for quite some time).
Is it possible to have worn fuel injectors but not see any significant correction values in the engine control module (ECM)? In my case, everything seems to be within the acceptable range so far.
I have a 1998 Volkswagen Golf III with a 66 kW ALE engine. It has 230,000 km on the odometer and these are the original injectors.
I'm noticing a slightly increased fuel consumption (around 6.3-6.5 liters per 100 km) and I have the impression that the car isn't accelerating as well as it used to.
However, I have to say that I've been driving mostly shorter distances lately, and I haven't been pushing the engine to its limits.
It would be great if someone could comment on this. The question is whether it's worth replacing the nozzles. It's not a cheap fix, and who knows how long the rest of the system will last.
Greetings.
El Capitan.
Translated on 24-08-2026, 6:46.
elcapitano2000
Post24-10-2006, 21:02    Subject: MWB13: Always an Indicator of Worn Injectors? Quote
oops... I spent 2 hours searching through the old posts and didn't realize that it had just been answered here: https://community.dieselschrauber.org/en/viewtopic.php?t=13694.
I would still be interested in hearing your assessment of the profitability.
Translated on 24-08-2026, 6:48.
No new posts TDI Injector Replacement: DIY Guide & Tips Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts MWB13: Performance Above Idle Speed Diesel Engine Technology
No new posts Crankshaft bolt AFN: Always replace? Diesel Engine Technology
No new posts KG Druck as an indicator of engine defect? Diesel Engine Technology
No new posts Exhaust Temp: Engine Load Indicator? Diesel Engine Technology
