Hello!
I need a little help with the 3.3 TDI AKF engine because I don't have the complete repair manual.
Can someone please tell me what the firing order is for the AKF engine?
I have read chapters 13 and 14 of the MWB.
http://www.harmoniedesoleuvre.lu/AudiA8/MWB_13_14_log1.xls
Der Diagnose nach zu urteilen müsste die Einspritzdüse (ED) des Zylinder 4 defekt sein, da konstant +2,49mg/H geregelt wird. ED 5 könnte von ED 4 beeinflusst werden wenn Zylinder 5 in der Zündreihenfolge vor Zylinder 4 liegt. LieAm I in the right place?
What is your opinion on the Audi regulation to replace all injectors? I plan to only replace the faulty injector and clean the remaining 7 with a special cleaner from BG Products.
Thank you in advance for any advice!
Raoul.
