Hi.
Quote: |
| Do you also have no idea how I can find out whether the LMM is actually defective or not? |
Measuring the output voltage can provide clues: insert a measurement lead into the interior, connect a voltmeter, and perform a full-load acceleration up to 4000 rpm. The voltage should continuously increase until it reaches approximately 4.5 volts (if I remember previous posts correctly).
If the voltage is too low, try cleaning it with brake cleaner spray. If nothing helps, then replace it.
