Passat 170PS TDI: Brake System Details
Post12-11-2006, 21:23    Subject: Passat 170PS TDI: Brake System Details Quote
The Passat has two different braking systems, which can be easily distinguished by looking at the rear brake discs: solid discs or internally ventilated discs.
What type of engine does the 170 hp TDI have?
The information I have is older than the engine itself, and its power output of 125 kW falls exactly in the no-man's-land between the performance limits of the two systems.
Thank you.
Translated on 30-08-2026, 19:31.
Post12-11-2006, 21:43    Subject: Passat 170PS TDI: Brake System Details Quote
I can only see a difference between the front bumper and the 4Motion model from the rear.
The "Frontkratzer" has 286 full-size 12-inch wheels.
The 4motion has internally ventilated brake discs with dimensions 310x22.
Translated on 30-08-2026, 19:32.
Post12-11-2006, 21:51    Subject: Passat 170PS TDI: Brake System Details Quote
My source says:
75-118 kW, 312x25 and 286x12 (full).
From 132 kW, dimensions 345x30 and 310x22 (air).
And with that, the 125 kW model probably doesn't have any brakes icon_eek.gif.
Translated on 30-08-2026, 19:33.
Post12-11-2006, 22:13    Subject: Passat 170PS TDI: Brake System Details Quote
I did some more research elsewhere:
front:
75-125 kW, Part Number 1LH/1LJ = 16" = 312x25.
184-206 kW, Front-wheel drive/All-wheel drive, PR number 1LK = 17" = 345x30.
rear:
75-125 kW, Part Number 1KU = 16" = 286x12.
184-206 kW, Part Number 2EA = 17" = 310x22.
Translated on 30-08-2026, 19:34.
Post12-11-2006, 22:18    Subject: Passat 170PS TDI: Brake System Details Quote
BTW: ... what is the 206 kW engine?
volkswagen.de only goes up to 184 kW (250 hp V6 FSI 4motion).
Translated on 30-08-2026, 19:35.
Post12-11-2006, 22:22    Subject: Passat 170PS TDI: Brake System Details Quote
dieselmartin wrote:
BTW: ... what exactly is the 206 kW engine?
3.6 l, 206 kW, 4motion, only for Japan and North America icon_wink.gif.
Translated on 30-08-2026, 19:36.
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Which engine control units are compatible with the Passat... On-Board Diagnostics (OBD)
No new posts Braking system Transmission, Chassis, Body & Interior
No new posts G60 Brake Kit for AFN Engine: Installation & Review Diesel Engine Technology
No new posts Bremsanlage mit ABS entlüften Transmission, Chassis, Body & Interior
