Needle Valve: Does it also apply?
haehnlein
Post29-09-2002, 22:25    Subject: Needle Valve: Does it also apply? Quote
Hello fellow DIY enthusiasts!
I've been experiencing the following issue with my Audi 80 TDI, manufactured in 1994 and with 250,000 km on the odometer: At 140 km/h (5th gear), the power suddenly drops, and the car stops accelerating. If I briefly release the accelerator and then press it again, the car accelerates up to approximately 160 km/h, and then the same issue occurs again, etc. This problem also occurs when driving uphill, in 3rd and 4th gear. What could this be? Thank you in advance! icon_confused.gif
Best regards, Christian.
Translated on 15-09-2026, 9:33.
haehnlein
Post29-09-2002, 23:55    Subject: Needle Valve: Does it also apply? Quote
Okay: I performed the knock test for the NHG at 3000 rpm -> no knocking!!! So, is it the MAF sensor?
Translated on 15-09-2026, 9:34.
Post30-09-2002, 10:43    Subject: Boost Pressure Issues: Troubleshooting Guide Quote
Hi.
I'm spontaneously thinking it's likely due to excessive boost pressure, which is causing the engine to go into limp mode with a reduced fuel injection amount.
Older TDIs will activate emergency mode as soon as the accelerator pedal is released.
Have the boost pressure read out during a test drive, or at least temporarily install a boost pressure sensor (LDA). The pressure should be approximately 0.9 to 1.1 bar under full load.
I'm less inclined to believe in the LMM, because you can't fix it by simply removing the gas. icon_cool.gif
Translated on 15-09-2026, 9:35.
haehnlein
Post26-10-2002, 16:13    Subject: Needle Valve: Does it also apply? Quote
Okay, so: a hose connected to the solenoid valve had a hole (it was worn through) -> it was replaced -> and now everything is fine.
Thank you to Ulf for the correct information!!!!!
Translated on 15-09-2026, 9:36.
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts Needle driver On-Board Diagnostics (OBD)
No new posts 1Z Needle Valve Actuator in ASV ??? Diesel Engine Technology
No new posts Needle Valve Injector Diesel Engine Technology
No new posts Needle Valve: Types, Function & Applications Diesel Engine Technology
