MSG Connector Pinout 184Nm 1Z
wolfi_b
Post30-10-2006, 9:31    Subject: MSG Connector Pinout 184Nm 1Z Quote
Hi everyone!
I am looking for the pinout diagram for the MSG (Motorknötungsgerät) of my Audi 80, model year 1993. It is the first 1Z model with 184 Nm of torque, with the part number 8A0 907 401B.
I'm actually only interested in finding out where the fan speed control for the air conditioning is located on the connector, and which pin (if the signal even comes from the main control unit) the kick-down deactivation for the air conditioning is located on.
"Additionally, knowing the pin numbering direction would be very helpful; I couldn't find any numbering."
Thank you very much. Best regards, Wolfi.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 10-10-2026, 17:04.
Post12-11-2006, 16:51    Subject: MSG Connector Pinout 184Nm 1Z Quote
You have a private message.
Translated on 10-10-2026, 17:05.
No new posts KST 1J0 959 799 Pinout: Connector Diagram & Info On-Board Diagnostics (OBD)
No new posts LMM Pinout: Switched Positive & Location Diesel Engine Technology
No new posts Pinout diagram for 1.7 SDI engine control unit On-Board Diagnostics (OBD)
No new posts ECU Pinout: Find Connector Pin Assignments On-Board Diagnostics (OBD)
