VAG-COM adapter not getting power!
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
makrospex
Post11-12-2006, 20:02    Subject: VAG-COM adapter not getting power! Quote
I just bought a used Volkswagen Passat, model B5 (3B), manufactured in 1999.
When I connect the self-built adapter, which I have been using without any problems for over a year on my old '96 Passat (and other, also newer VAG vehicles), to the ODB interface in the center console and turn on the ignition, the first red LED does not light up - meaning: The adapter is not receiving power from the vehicle's side. The LED test in VAG-COM is successful, but during the adapter test, the software naturally displays "Interface not found or ready." icon_sad.gif
What could be the reason for this? The diagnostic port in a car probably isn't individually secured.
macro
EDIT:
"Of course, the ODB connector and the VAG-COM adapter were electrically tested; there were no interruptions or short circuits."
The +12V connection is also available between pin 4 and 16 on the connector located in the center console.
Even when the ignition is off...
A few days ago, I tried using the adapter to read data from an Audi 80 manufactured in 1994 (which has a 2x2 connector). The adapter was working at that time, but no data connection could be established: "Cannot sync baud rate." However, this shouldn't have damaged the adapter...
Opel Vivaro Kombi, 2.0 CDTI 110kW BlueHDI (MKB: AH01), BJ 2020
Translated on 18-07-2026, 13:49.
makrospex
Post11-12-2006, 23:18    Subject: VAG-COM adapter not getting power! Quote
After a somewhat longer search, I have now found the error.
The contacts in the diagnostic socket (in the vehicle) were so widened that the adapter's connector could not make a reliable connection. Only when I plugged in the connector and then positioned it at an angle (a few degrees longitudinally), did the adapter receive power from the socket. icon_rolleyes.gif
Regarding the cause of the widened contacts in the socket, I can only speculate, but it seems that a technician with little sensitivity may have been involved icon_evil.gif.
@Admins: If you believe the information in this thread is adequately covered by relevant articles, please delete this thread. Thank you!
macro
Translated on 18-07-2026, 13:52.
Ross-Tech-Support
Post12-12-2006, 13:33    Subject: VAG-COM adapter not getting power! Quote
Out of curiosity, what kind of interface (manufacturer) do you use?
Translated on 18-07-2026, 13:53.
makrospex
Post12-12-2006, 13:42    Subject: VAG-COM adapter not getting power! Quote
I'm using the self-built RS232 interface from Rainer's shop along with one of those blue USB-to-serial adapters (I don't remember exactly who makes them, but they work well with VAG-COM and I think they are also available for purchase in Rainer's shop).
Perhaps I will upgrade to the USB-HEX someday, if I need a batch for tax depreciation icon_wink.gif.
macro
Translated on 18-07-2026, 13:54.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Diag. Adapter über USB-Adapter:Login nur in Motorsteuerg... On-Board Diagnostics (OBD)
No new posts B5 KI mit Strom versorgen On-Board Diagnostics (OBD)
No new posts Rear window wiper / No power Diesel Engine Technology
No new posts AUY Control Unit: Sharan Power Supply & Issues On-Board Diagnostics (OBD)
