Central locking system for Passat Variant 3B 2.5 TDI V6 AFB, manufactured in 1999
b.driesen
Post10-01-2007, 1:31    Subject: Central locking system for Passat Variant 3B 2.5 TDI V6 AFB, manufactured in 1999 Quote
I'm having the following problem: When I lock the car with the remote, all the doors close. However, the turn signals don't blink. Only on the second or third press of the button.
I know I'm supposed to use the search function. I have done so, and I'm supposed to look for "broken traces" or "cold solder joints" for the following error. However, since my control unit (46) is reporting four errors, I hope someone might be able to immediately say: "Yes, those are the microswitches on the driver's door, or something similar."
Okay, here's the transcript:
Address 46
Control unit: 1J0 959 799 AH
Component: 33 Central SG Comfort Unit 0001.
Encoding: 04097
Shop #: WSC 05311
4 errors found:
00928 - Door lock module for central locking, driver's side (F220)
27-00 - implausible signal.
00912 - Front left window switch (E40)
27-10 - implausible signal - interrupted.
00913 - Window switch for front right window: Driver's side (E81).
00944 - Passenger side mirror heating (Z5)
35-00 - -
Thank you in advance for your replies.
And best regards from the "Ruhr area".
Bernd.
Post10-01-2007, 9:56    Subject: Central locking system for Passat Variant 3B 2.5 TDI V6 AFB, manufactured in 1999 Quote
If so many things are happening at the same time with the driver's door, it probably sounds like a broken cable.
What happens if you delete the codes?
Will they come back?
- all of them, immediately.
- sequentially
- one after the other
- in sequence
- sometime, but then all at once.
At the very least, the first and last behaviors strongly suggest a cable break.
Herr Antje
Post10-01-2007, 10:05    Subject: Central locking system for Passat Variant 3B 2.5 TDI V6 AFB, manufactured in 1999 Quote
Are you having any problems with the interior lighting? Does the interior lighting sometimes turn off even when the door is open or in another unusual state?
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
b.driesen
Post12-01-2007, 0:01    Subject: Central locking system for Passat Variant 3B 2.5 TDI V6 AFB, manufactured in 1999 Quote
So,
I haven't had any problems with the interior lighting. I've already cleared the error messages. Whenever I turn the ignition on and off, the error related to the heated mirrors reappears immediately.
The error.
It happens when I lock and unlock the car using the remote control or the key.
The others haven't returned yet. But I remember that the power window for the driver's side door made a strange noise for a short time a while ago.
Okay, so, cleaning the microswitches in the door lock and resoldering the contacts?
Herr Antje
Post12-01-2007, 8:26    Subject: Central locking system for Passat Variant 3B 2.5 TDI V6 AFB, manufactured in 1999 Quote
b.driesen wrote:
So, should I clean the microswitches in the door lock and resolder the contacts?
That's where I'd start, because it's free and microswitches are often the culprit.
Aktuell:
BM
Avatar-BM
Post12-01-2007, 14:20    Subject: Central locking system for Passat Variant 3B 2.5 TDI V6 AFB, manufactured in 1999 Quote
I would start with that, because it costs nothing, and the microswitches are probably often responsible for it.
That's exactly what I would do too. Pay particular attention to properly soldering the connections of pins 7 and 8 (photo), and possibly add a jumper wire.
Most often, contact 7 (at the connector housing) is the cause. This also provides a ground connection for the other three microswitches.
 File size:  25.01 KB
 Viewed:  7960 times
3B5 AJM
No new posts Customization options for Volkswagen central locking systems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Central Locking Adjustment Options Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tankklappenentriegelung failure Golf 5 Variant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Remote Central Locking VW Passat Diesel Engine Technology
No new posts Shock Absorber Replacement VW Passat 3B Variant Transmission, Chassis, Body & Interior
No new posts Mass Air Flow Sensor Problem: VW Passat Variant 2.5 TDI Diesel Engine Technology
No new posts Passat Variant: Brake Caliper Piston Problems Transmission, Chassis, Body & Interior
