Box + Chip = Problems?
Switch
Post02-05-2002, 10:17    Subject: Box + Chip = Problems? Quote
Hi everyone...
I have a question. Since I have a chip in my 3rd Golf TDI and it's quite bad (smoke, etc.), we installed an additional 'black box' in it yesterday, the kind that you insert into the fuel injection system. Now, my question is: Does this device actually do anything? I haven't noticed anything different. Is it bad for the control unit, since there are now two power increases? A friend of mine said that it's possible that the control unit could be damaged if you have both a chip and a box in it.
Thank you in advance.
Jan6K
Avatar-Jan6K
Post02-05-2002, 10:37    Subject: No addition! Quote
Performance improvements don't add up!
In case of doubt, the box distorts the signals so that the control device cannot process them properly, especially since it is not running the original program, but rather the tuning program of the chip. And together, this results in utter chaos...
... OR...
... there's so much pressure that it can easily melt the pistons, either too quickly or too slowly!
I would advise against doing that!
Each tuning part starts from the "normal state," and this state doesn't actually exist; the box is therefore not running in the environment for which it was designed, and neither is the chip.
Jan
1Z5 CFHF / AHB H4D
Post02-05-2002, 16:38    Subject: Topic renamed Quote
Hi Switch
I have renamed your topic. The original title "Elektrik" seemed too general, as it could also refer to batteries, starters, connectors, etc.
Essentially: the control unit cannot be broken easily - at most, it will reach the point of frustration, so that it operates in emergency mode and emits a SOS signal via a light bulb. . .
JET
Post02-05-2002, 18:15    Subject: Box + Chip = Problems? Translating...
[Translating...]Hallo, Chip und Box zusammen funktionieren nicht, du mußt dich für eines entscheiden. Ich persönlich bevorzuge einen Chip. Wenn du mit deinem unzufrieden bist, dann versuchs mal mit einem von einem anderen Tuner. Willst du jedoch die Box verwenden, dann brauchst du im Steuergerät wieder die Seriensoftware.
Stefan
Post03-05-2002, 8:20    Subject: Box + Chip = Problems? Translating...
[Translating...]von welchem tuner ist denn dein chip ??
chip & box passt nicht zusammen.
vor allem ist das doch so, daß wenn dein motor eh schon russt
und du ihm jetzt noch mehr sprit gibst, dann wird er doch nicht weniger russen !! das verstärkt nur die negativen eigenschaften.
nimm die box lieber wieder raus. du riskierst einen kapitalen motorschaden !!
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tempomat-Einbau-Probleme Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Chip 115 PS PD Diesel Engine Technology
No new posts AFN Chip: What it is and how it works On-Board Diagnostics (OBD)
No new posts TÜV and Chip: What You Need to Know Diesel Engine Technology
No new posts AFN mit Chip und Zahnriemenwechsel? Diesel Engine Technology
