mhernach Guest
06-11-2006, 7:00 Subject: Breaking in a new turbo? |
Hi everyone...
I may be an expert in the field... but there are  things that no one knows.
Okay, so I have a new turbo installed... The turbo boost wasn't quite right; it came on too late during acceleration.
Okay, I've been driving for about 2000 km now, and I've noticed that my car is running much better than it was before!
Could it be that a turbocharger needs some time to reach its full boost pressure?
or am I just imagining it  ?
Michael.
Herr Antje Schrauber
Joined: 01/18/2006 Posts: 1547 Karma: +7 / -0 Location: Nahe Tübingen
06-11-2006, 9:04 Subject: Breaking in a new turbo? |
Unfortunately, I don't know either, but I can't imagine it. Since the settings would be adjusted anew, the adjustment would be pointless. It's possible that the VTG mechanism operates more smoothly and therefore reacts more quickly. Or are you talking about a waste of time?
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
06-11-2006, 9:17 Subject: Breaking in a new turbo? |
Hi Tom,
Michael has a boxed 1Z and that makes him a waste. (as can be seen in his spectacular ripped photos  ).
I also feel sick every time I have to go back from the Leon ASV to my Golf.
Only outside the city, when the engine speed and turbo boost are already high, I prefer to drive a Golf  .
Profile PM Garage |
06-11-2006, 10:52 Subject: Breaking in a new turbo? |
 Sorry!!
Then it must be due to the storage conditions. If it generates a larger "resistance" when it's new... that should also be transferable to the VTG system, and there's an adjustment setting for that. I find it hard to imagine...
Aktuell:
christians Profi-Schrauber
06-11-2006, 12:42 Subject: Breaking in a new turbo? |
It's probably more likely to be a side effect, for example, the exhaust/catalytic converter might have become clear after the turbocharger started working correctly again.
Gruß Christian
charlyfirpo Blaumann
Joined: 09/02/2006 Posts: 155 Karma: +6 / -0 Location: DM 2013 Volkswagen Golf Support
11-11-2006, 8:21 Subject: Breaking in a new turbo? |
Hello.
I can confirm that as well. At 71,000 km, VW also replaced my turbocharger. It took about 2-3 thousand kilometers for the engine to run as well as it did with the old charger.
I also think the resistance in the loader is due to the pressure from the container.
I'm familiar with that from large diesel engines in tractors. The new loaders were initially running a bit "rough."
Best regards, Charly.
Golf 4 GTI TDI, ARL Serie 346031 Km
Webasto Thermo Top E
15.02.2013 -> Golf 6 GTD DSG CFGB/NLN, TT-V+T91R
21.03.2016 -> Golf 7 R, Limestonegrey, 19", Voll...
Profile PM Garage |
Aron Blaumann
Joined: 10/26/2006 Posts: 440 Karma: +5 / -1 Location: KC
21-11-2006, 19:58 Subject: Breaking in a new turbo? |
charlyfirpo wrote: | Hello.
Best regards, Charly |
I also encountered similar problems when I was rebuilding my turbocharger and adjusting the boost pressure.
The engine control units detect the aging of the mass airflow sensor by comparing the desired and actual mass airflow curves under full boost pressure. So, if you have a new loader, the response might be different in the lower and upper RPM ranges, and it might take a while for you to get used to it.
To break in the loader:
I once had the opportunity to disassemble a new KKK turbocharger. The brass bushing in the bearing had a clearance of 3/100mm relative to the shaft of the compressor wheel, and the same clearance relative to the outer engine block. Due to the oil pressure, this brass bushing floats internally and externally on an oil film, so there should be no contact between the materials. This is also the reason why the turbochargers sometimes have a certain amount of play, which disappears when oil pressure is applied. With a bearing clearance of 3/100mm, the total clearance over the double stroke of the two turbines (the bearing accounts for about 1/3 of the shaft/axle length) results in a normal clearance of over 2/10mm. Therefore, a break-in period is unnecessary. As I mentioned, the electronics are the key issue.
Aron
22-11-2006, 12:47 Subject: Breaking in a new turbo? |
Aron wrote: |
This does not apply to VAG engines.
I haven't noticed anything like that with my new one either.
Gruß Christian
Mephisto Profi-Schrauber
23-11-2006, 16:02 Subject: Breaking in a new turbo? |
Quote: | | I also think that the resistance in the loader is due to the friction within the bearing. |
Are the rotor shafts not hydrodynamically lubricated? There is no contact between the wave and the housing.
"Micha"
matthiasTDI96 Profi-Schrauber
23-11-2006, 19:04 Subject: Breaking in a new turbo? |
I absolutely cannot imagine that anything will change, and if it does, you'll need to get the next new loader. As my predecessor mentioned, the wave is "surfing" beautifully within an oil film that surrounds it.
It can really only be due to side effects. Of course, you shouldn't demand the maximum load pressure immediately after installation, but 2,000 kilometers of break-in period? How so?
So, after the second trip, just drive normally like before. Does the beast then survive, was it scrap from eBay or natural selection  ?
Madness Guest
27-11-2006, 20:10 Subject: Breaking in a new turbo? |
My brother-in-law works in loader development. According to his statement, a charger cannot be 'broken in' in the same way as an engine.
'Simply use it reasonably' were his words  .
