Error Code P1524: Troubleshooting Guide
HelmutD
Post27-11-2006, 17:38    Subject: Error Code P1524: Troubleshooting Guide Quote
"In my Octavia (manufactured in 2004), with the ATD engine, the following error code is stored: "Fuel pump relay J17 - interruption/short circuit to ground." I have run the Skoda diagnostic program and found no errors. I replaced the fuel pump relay and cleared the error. Initially, everything seemed fine, but after about 120 km, the warning light came on again with the same error code stored. There are no noticeable issues with the car's performance. I would be very grateful for any help."
Best regards, Helmut.
Translated on 11-08-2026, 19:38.
Ross-Tech-Support
Post27-11-2006, 21:40    Subject: Error Code P1524: Troubleshooting Guide Quote
Please provide us with a proper and, above all, complete diagnostic report.
Translated on 11-08-2026, 19:39.
HelmutD
Post28-11-2006, 18:10    Subject: Error Code P1524: Troubleshooting Guide Quote
Self-diagnosis protocol for VAS5052.
OBDMode3: Fault Memory
P0230 Fuel Pump Relay J17 - Electrical Circuit Fault
Address 00
Engine control unit fault memory: 17932 P1524 035 Fuel pump relay J17 - Open circuit or short to ground.
Fuel pump relays and power supply relays replaced, electrical wiring and connections checked, no faults found.
The error only occurs after approximately 100 kilometers of driving.
Helmut.
Translated on 11-08-2026, 19:40.
Ross-Tech-Support
Post28-11-2006, 19:08    Subject: Error Code P1524: Troubleshooting Guide Translating...
[Translating...]
http://wiki.ross-tech.com/index.php/17932/P1524/005412
HelmutD
Post29-11-2006, 7:43    Subject: Error Code P1524: Troubleshooting Guide Quote
Thank you so much, that has been incredibly helpful.
Translated on 11-08-2026, 19:41.
No new posts Error code P1351 General Tips
No new posts ESP function test, error code 01486 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code 01276 - ABS hydraulic pump (V64) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code Diesel Engine Technology
No new posts 2.5 TDI Error Codes: AAT & More Diesel Engine Technology
No new posts Error Code 575: Intake Manifold Pressure Problem Diesel Engine Technology
No new posts AFN Error Code 00550: Troubleshooting Guide Diesel Engine Technology
